Replace mesh in the case file
Old   December 10, 2008, 09:22
Default Replace mesh in the case file
Alex
I would like to replace the mesh in a case what i ran with a other one. All numerical parameters and methods should be not changed. How I can perform this in STAR 4?
What I'm looking for to do is like "write-bc" in Fluent (writing of boundary condition file). It would be nice to have the same setup with a new mesh.
Old   December 10, 2008, 11:33
Default Re: Replace mesh in the case file
Pauli
In v3.26, the command cdsave writes out the model. Give it a look & see if it's what you want. It's been a while since I've used it & I don't remember all the details.
You probably only want the casename.inp file since you have a new grid. You will need to create the boundary regions on the new mesh. And you may have to edit the case.inp file created by cdsave.
Modifying a mesh starting from case file Ale FLUENT 2 September 16, 2008 12:10
Initial condition data file from coarse mesh case Kushagra FLUENT 1 July 25, 2008 21:53
Export mesh from case file in fluent Sonia FLUENT 1 February 22, 2007 14:09
new mesh, same case file student FLUENT 1 January 29, 2007 10:37
Changing gambit file without change of case file?? Asghari FLUENT 2 August 28, 2006 13:48
