December 10, 2008, 10:22 |
Replace mesh in the case file
I would like to replace the mesh in a case what i ran with a other one. All numerical parameters and methods should be not changed. How I can perform this in STAR 4?
What I'm looking for to do is like "write-bc" in Fluent (writing of boundary condition file). It would be nice to have the same setup with a new mesh. |
December 10, 2008, 12:33 |
Re: Replace mesh in the case file
In v3.26, the command cdsave writes out the model. Give it a look & see if it's what you want. It's been a while since I've used it & I don't remember all the details.
You probably only want the casename.inp file since you have a new grid. You will need to create the boundary regions on the new mesh. And you may have to edit the case.inp file created by cdsave. |
Display Modes | |
Modifying a mesh starting from case file | Ale | FLUENT | 2 | September 16, 2008 13:10 |
Initial condition data file from coarse mesh case | Kushagra | FLUENT | 1 | July 25, 2008 22:53 |
Export mesh from case file in fluent | Sonia | FLUENT | 1 | February 22, 2007 15:09 |
new mesh, same case file | student | FLUENT | 1 | January 29, 2007 11:37 |
Changing gambit file without change of case file?? | Asghari | FLUENT | 2 | August 28, 2006 14:48 |
