December 18, 2008, 16:54 |
Initial velocity field in StarCCM+
I want to initialize a 3D velocity field to my problem
u(x) = f(y) = a cubic velocity profile u(y) = 0.0 u(z) = 0.0 I understand the scalar field function but not quite sure how to implement this vector field to my problem. f(y) will look like : a*pow($$Position[1],3) + b*pow($$Position[1],2) + c*$$Position[1] All the vector field function examples are kind of problem specific and I am unable to figure out how I will achieve what I am trying. So if anyone could point me in the right direction then that will be great. |
December 18, 2008, 17:17 |
Re: Initial velocity field in StarCCM+
The field function you are looking for is $$Centroid not $$Position.
Just paste the code you have written into a new field function definition, and set the initial velocity in the x direction to use that field funciont. |
December 18, 2008, 17:22 |
not quite following what you are trying to say here.
Why should I use centroid first of all? Secondly, should this be a scalar or vector field function? if scalar and u(x) only how will I make sure u(y) and u(z) = 0, respectively? |
December 21, 2008, 04:40 |
Hi
Make your FF (field function) of type vector not scalar. Give it the definition [0,0,$YourFieldFunction] You can use position, it is the vertex position and is known to STAR-CCM+ before you hit initialise. The value of centroid is calculated during initialisation. With position there can be potentially problems with tolerances particularly if you try a FF containing for example a sqrt operation if a vertex position falls below zero , hence I like to use centroid. Regards Steve |
Display Modes | |
Help for the initial field 4 lid-driven flow | John | Main CFD Forum | 4 | October 22, 2008 06:18 |
How to set initial field for supersonic flows | Qu Kun | Main CFD Forum | 0 | March 4, 2006 08:57 |
initial field of turbulence | Paul | Main CFD Forum | 1 | May 25, 2002 06:53 |
Q:Vane initial field with tascflow. | lhb | CFX | 1 | June 14, 2001 12:39 |
Initial turbulent field | Tony Chen | Main CFD Forum | 10 | July 19, 1999 01:52 |
