Initial velocity field in StarCCM+
Old   December 18, 2008, 15:54
Default Initial velocity field in StarCCM+
Subhadeep
I want to initialize a 3D velocity field to my problem
u(x) = f(y) = a cubic velocity profile
u(y) = 0.0
u(z) = 0.0
I understand the scalar field function but not quite sure how to implement this vector field to my problem.
f(y) will look like :
a*pow($$Position[1],3) + b*pow($$Position[1],2) + c*$$Position[1]
All the vector field function examples are kind of problem specific and I am unable to figure out how I will achieve what I am trying. So if anyone could point me in the right direction then that will be great.
Old   December 18, 2008, 16:17
Default Re: Initial velocity field in StarCCM+
a
The field function you are looking for is $$Centroid not $$Position.
Just paste the code you have written into a new field function definition, and set the initial velocity in the x direction to use that field funciont.
Old   December 18, 2008, 16:22
Subhadeep
not quite following what you are trying to say here.
Why should I use centroid first of all?
Secondly, should this be a scalar or vector field function?
if scalar and u(x) only how will I make sure u(y) and u(z) = 0, respectively?
Old   December 21, 2008, 03:40
steve
Hi
Make your FF (field function) of type vector not scalar.
Give it the definition [0,0,$YourFieldFunction]
You can use position, it is the vertex position and is known to STAR-CCM+ before you hit initialise. The value of centroid is calculated during initialisation.
With position there can be potentially problems with tolerances particularly if you try a FF containing for example a sqrt operation if a vertex position falls below zero , hence I like to use centroid.
Regards
Steve
Help for the initial field 4 lid-driven flow John Main CFD Forum 4 October 22, 2008 05:18
How to set initial field for supersonic flows Qu Kun Main CFD Forum 0 March 4, 2006 07:57
initial field of turbulence Paul Main CFD Forum 1 May 25, 2002 05:53
Q:Vane initial field with tascflow. lhb CFX 1 June 14, 2001 11:39
Initial turbulent field Tony Chen Main CFD Forum 10 July 19, 1999 00:52
