January 7, 2009, 10:43 |
Help needed
Hello I am modeling a U bend channel in STAR CCM+. I want to get the Temperature and velocity scales as output from the channel in form of a tabulated data or plot. I want to use it as input profile to the other channel. Can anyone help me how to do it??. Regards Waseem
January 7, 2009, 13:40 |
Re: Help needed
Under Tools > Tables, create a new XYZ internal table. Add your outlet boundary under parts, then add the scalar's you want. Right click, and export to a .csv file.
Next open the new model, create a new table from file. Then you can define whatever parameters you want based on the table. This is assuming that the outlet from the original and the inlet from the new are in the same XYZ location. If not, transform the new mesh to make the locations match. |
January 7, 2009, 13:44 |
Re: Help needed
thanks alot....this is of great help. Can I conyact you directly in near future? Regards Waseem
Display Modes | |
Help Needed | S | FLUENT | 5 | April 22, 2008 13:58 |
Help Needed | Saravanan | FLUENT | 1 | April 12, 2008 21:14 |
Help Needed | Saravanan | FLUENT | 0 | April 3, 2008 17:07 |
help needed | vivek | FLUENT | 1 | November 15, 2006 05:28 |
Help needed with UDF | sam | FLUENT | 5 | October 26, 2005 03:48 |
