Home > Forums > CD-adapco
Error Orient Face incorrect
Old   January 14, 2009, 11:42
Default Error Orient Face incorrect
MK
Hello All, I am preparing the mesh for Heat Exchanger considering solid and fluid surface mesh. But I face the error : orient face ( incorrect) outward - cannot volume mesh. Could you please suggest how to fix it?
Thanks
Old   January 14, 2009, 13:13
Default Are you using Star-CD/CCM to generate the mesh?
Nicole Price
Is it possible you have a negative cell volume, resulting in an invalid face?
I'd recommend you run the mesh diagnostics and allow the software to repair the cells, or faces, on the fly.
Old   January 14, 2009, 23:47
Default Re: Are you using Star-CD/CCM to generate the mesh
MK
I am using starccm+ for meshing. I have already check the mesh and ccm+ show its correct
the error is
Surface is not closed -- cannot orient outward Surface is not manifold -- cannot orient outward Input surface to surface remesher is not oriented outward. Checking proximity in both directions ---------------------------------------- Executing Surface Remesher ----------------------------------------
Old   January 15, 2009, 02:29
ping
You mentioned you are doing a heat exchanger with solid and fluid regions. Note the message also says Not Manifold - so it sounds like your surfaces and interfaces have not been well defined - read the extensive help on multi-region meshing, and then make the required changes to ensure your have good interfaces between your regions. I also suggest you do this tutorial first: Training Guide > Meshing Tutorials > Heat Exchanger Unit Meshing Tutorial
Old   January 16, 2009, 05:49
rabat
I suggest you need to create a interface between the solid and fluid, with -> convert to interface.
Witch turbulentmodell do you use in your simulation?
Rabat
Old   January 19, 2009, 09:46
MK
Yes its correct .I did it. K-epsilon with 2 layer model
Thread Tools
Trackbacks are On
how changing the image back to orient angle pc FLUENT 1 July 2, 2008 11:10
what is orient block in icem? suresh CFX 0 April 19, 2007 12:52
what is orient block in icem suresh CFX 0 April 13, 2007 10:33
what is the concept of orient block? nina CFX 0 April 6, 2007 12:54
*** ERROR #320 *** INCORRECT WALL HEAT BOUNDARY... bv CD-adapco 2 September 12, 2005 03:09
