-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   VOF error when initializing (http://www.cfd-online.com/Forums/cd-adapco/56961-vof-error-when-initializing.html)
Simone January 21, 2009 07:33
When initializing turbulent flow for VOF calculation, solver get me this error:
"Warning: Initializing turbulent flow with density unavailable in fluid! Density of 1 kg/m^3 assumed for computing initial turbulence quantities."
What is it?? How can I avoid this error??
Thank a lot
Andrea January 21, 2009 08:12
Re: VOF error when initializing
There's no problem, simply the turbulent flow field will be initialized using a standard density value. Next the turbulent flow will be calculated coerently with the exact density of the fluid...
It's just the initialization
Simone January 21, 2009 09:07
...ok, but after a few iteration simulation diverge and the iso-surface at VOF=0.5 assume unphysical shape....
With laminar model I don't have this problem!
Any idea??
Andrea January 21, 2009 09:19
what kind of simulation is? Steady, transient...and also: underelax, boundary, initialization field/functions...?
Simone January 21, 2009 09:27
Simulation is VOF unsteady, underelax low (0.4, 0.3 etc..), wov wave first order, 6DOF frozen for computing hyrodynamics forces on a ship hull.
Similarly of the demo from CD-Adapco for DFBI, i set the correct bondary conditions, but i change turbulent model...so from laminar to k-omega. Mesh is ok, with B.L.y+=50.
Time step 0.01s
Do you have any experience on this problem?
Adam January 21, 2009 14:27
Are you using first or second order time Discretization?
Simone January 21, 2009 15:08
second order
Simone January 21, 2009 15:09
and first order for time!
Adam January 21, 2009 17:00
Try changing the turbulence specification to K + Epsilon on both the initialization and the inlet.
Andrea January 23, 2009 08:18
if it doesn't work try initializing the sim with first order scheme...then switch to second order later
It's a general tip, I'm sorry but I don't have experience in this kind of sim...but the initialization it's similar to other ones...
star February 3, 2009 20:35
Have you tried lowering the time step? Are you using ccm+ or v4? In v3 I always faced problem when the time step is that large (0.01s). In v4 this seems less a problem. I think I read on the manual or somewhere VOF is not yet able with k-omega or other turbulence models. For DFBI, it might not even able to handle k-E but I'm not sure. BTW, I'm curious to know how long it takes you to complete this run.. the elapsed time I mean... when you complete this job later. (Just curious if you dont mind).
jimmer February 11, 2009 12:26
I think VOF and turbulence don't go together in STAR-CD. The software calculates granular variables and the only correct choice there is laminar flow.
