-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   Star CCM+ issue (VOF and Non newtonian power law) (http://www.cfd-online.com/Forums/cd-adapco/56964-star-ccm-issue-vof-non-newtonian-power-law.html)
Sam January 22, 2009 09:06
Hello everyone,
I have an issue with a case: I want to study a bubble injection in a liquid whose viscosity is characterized with the herschel bulkley law (Non newtonian generalized power law in star CCM+). It seems that there are some incompatibilities between VOF and this viscosity model. The simulation won't run and I have this message : "Attempt to access unallocated NonNewtonianViscosity storage in cells in fluid "
I have tested VOF with constant liquid viscosity : it works
And single phase flow with the Non newtonian generalized power law : it also works.
If someone has a solution or is aware of this, it would be great.
Thanks a lot
Sam
donald January 22, 2009 18:00
Re: Star CCM+ issue (VOF and Non newtonian power l
the best is to specify viscosity through field function. it works ok
Sam January 23, 2009 04:26
Oh ok, thank you for your answer !
Now I'll have to the variable name for the strain rate, gonna have a look in the guide, unless you know it ? :)
Thanks again. Sam
Sam January 23, 2009 08:39
I found the solution. Actually the default settings do not provide all the field function. One must activate "Temporary Storage Retained" in the "Solver" "Segregated flows". Then Strain rate variable and other cell gradients can be reached.
