About run problem
Old   February 11, 2009, 02:50
Default About run problem
suresh
I am using star CD for simulating compressible flow.I have two inlet and one outlet. Out of two inlets one is mass inlet while other is pressure inlet. Outlet is pressure outlet. I am not using stagnation or environmental pressure boundary for my problem.
I have defined ULR as given below: for u,v,w: 0.4
p: 0.12
k,e:0.4
T:0.90
den : 1 I am using density as function of pressure and temperature. For first 300 iterations I treated problem as incompressible later I converted density as fiunction of pressure and temperature.Then,I made star to perform 4000 iterations.But I am observing that my mass residual is continueously fluctuating around 6x10-3. while other residuals have gone below 10-4. Can anybody please answer following questions:
1) Do I have achieved convergence?
2)If I have not near the convegence then how to bring down mass residual below 10-4?
Any suggestions from expert is most welcome.Thanks in advance.
Old   February 12, 2009, 03:15
Default Re: About run problem
Andrea
Try to monitor the mass flux, the pressure distribution and other charactheristics you may be interested in on your simulation (for example with boundary monitor option on). If they change a little or if they don't change appreciably with the progress of you calculation than you can argue that you've reached convergence.
If it is not as above then you may want to switch to a transient simulation to obtain a more realistic result from your model, involving transient phenomena you can't obtain in a steady state simulation.
Sometimes the geometry is not so simple so maybe in you model born some phenomena like vortex-shedding, recirculating region, etc...and you need a transient sim to describe them.
Regards.
VOF diffuse problem on two fluids problem Fang Jin FLUENT 5 February 17, 2011 05:38
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 09:37
Problem in cavity flow problem saad Main CFD Forum 4 November 1, 2007 07:45
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
problem in solving "wave generation" problem san FLUENT 2 April 3, 2006 23:37
