Transport properties with PPDF combustion
Old   February 18, 2009, 05:18
Default Transport properties with PPDF combustion
Erik
Hi all, I'm simulating combustion using the PPDF model. Therefore, I've succesfully defined the reaction mechanism and thermodynamic properties in CHEMKIN format. When I take a look in the chemf.out01 file, it is stated that there are no errors found in reaction mechanism. But when I look in the tranf.out01 file, the following is stated:
TRANFT: Transport property fitting,
CHEMKIN-II Version 3.0, November 1990
DOUBLE PRECISION
OUTPUT FROM THE TRANSPORT PROPERTY FITTING
THERE IS AN ERROR IN TRANSPORT PROPERTY CALCULATION !
The transport properties are defined in CHEMKIN format, in a file called tran.dat. But for some reason Star can't read these properties. The manual does not state anything about this, so does someone know how to solve this problem?
Thanks!
Mixture fraction with PPDF combustion Erik Siemens 1 September 5, 2011 21:47
Laminar diffusion flames and reactingFoam Transport properties jgaricano OpenFOAM Running, Solving & CFD 0 June 4, 2008 16:58
Methane combustion using PPDF CPRL Siemens 0 July 19, 2007 13:28
Problem with transport properties depending on Temperature galaad OpenFOAM Running, Solving & CFD 5 December 6, 2005 12:51
transport properties of gases cfd sutdent Main CFD Forum 2 April 29, 2004 09:41
