Simulating air injecting to water in a tank?
Can STAR-CD simulate air injecting thru. a tube to water in a tank? I believe this is a problem of fluid interaction or fluid mixing, not multiphase flow.
If connot, which CFD code can handle this? Thanks, HW |
Re: Simulating air injecting to water in a tank?
since you have 2 phases: air & water, it is a multiphase flow problem
The standard VOF model in either STAR-CD or STAR-CCM+ will handle this case - you need to keep the cell sizes down in the order of the tube size and resulting bubbles to capture the bubbles well. Otherwise try the Eulerian-Eulerina model.
