Geometry translation
Old   April 23, 2009, 06:43
Default Geometry translation
wei
wei
wei is on a distinguished road
I want to rotate and translate a geometry to a new location. How do I do that?
wei is offline   Reply With Quote
Old   April 23, 2009, 09:14
Aroon
vishyaroon is on a distinguished road
If you are using STAR CD use the vgen command. For translation you can use this directly. The syntax of this command (explained through an example is):
cset all
vset news cset
vgen,2,0,vset,,,dx,dy,dz (replace dx, dy and dz accordingly)
The above example is for translating. You'd have the Cartesian co-ordinate system on in such a case.
If you want to rotate the geometry activate the cylindrical co-ordinate system and then use the vgen command to rotate.
vishyaroon is offline   Reply With Quote
Old   April 23, 2009, 09:16
Aroon
Sorry forgot to mention that if you are using STAR CCM+, it is straight forward. Right click on the region and you'd see the transform option. This has rotate, scale, translate options.
Old   April 23, 2009, 10:38
wei
wei
It is working well. Thank you. I am using starcd 3.26.
If I want to add a new mesh using current surface model on top of the top layer of a previous mesh, what can I do?
Old   April 27, 2009, 11:30
Anton Lyaskin
A_Lyaskin is on a distinguished road
You can create a surface mesh (shells) at the top and then extrude it (see help for VCEXTRUDE command)
A_Lyaskin is offline   Reply With Quote
Old   April 28, 2009, 04:50
wei
wei
what commands are normally used to create a surface mesh (shell) from vertices?
thank you.
Old   April 28, 2009, 06:59
Anton Lyaskin
If you already have a 3D mesh, you can use CFIN command with SHELL option (from GUI: Tools->Cell Tool->Add Shells->Surface (New edge Vertex Set)...)
Importing CAD geometry and Editing edges to match Ahmed CFX 15 March 21, 2016 12:39
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry villier OpenFOAM Meshing & Mesh Conversion 17 June 15, 2010 19:51
urgent help! car geometry Arjun FLUENT 0 August 13, 2007 13:07
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
Input Geometry from Ideas to Gambit Knick FLUENT 2 December 11, 2002 03:59
