EBU eddy break up unpremixed combustion for diesel |
April 29, 2009, 07:29 |
mosheu
hi
how do you use ebu for unpremixed model, did you close cfm or ecfm models in esice hkoten@hotmail.com |
April 29, 2009, 07:42 |
mosheu
who use EBU combustion models for unpremixed....
April 29, 2009, 11:18 |
Pauli
You can use EBU for un-premixed diesel combustion. You do not need es-ice.
Define the reaction, define the ignition, define the spray, initialize the scalars & you should be done. If it doesn't work, read the methodology and user manuals. Then post specific questions & details regarding what went wrong. |
April 29, 2009, 11:26 |
mosheu
thank you pauli
I am studying in-cylinder diesel combustion modeling I meshed in esice, in prostar start of inj. 700CA end of inj 735CA and ignation in 705CA, but temperatures arent increasing~1000K |
September 1, 2010, 15:47 |
Pro-Star: Shell Modeling
#5 | |
Amit
Hi, I have been trying so many different reaction models but all of them have failed. How do you know that un-premixed combustion with EBU standard is the best model for diesel combustion? Could you tell me what's the best combination reaction model and type for Diesel combustion simulation in Pro-Star? Thank you in advance. Amit |
September 1, 2010, 17:55 |
Pauli
I never claimed EBU was the best model. ECFM-3Z should be superior. Flamelet models should be superior.
What do you mean by failed? Did it not "burn"? Or do you not match a measured pressure trace? |
September 1, 2010, 22:06 |
#7 | |
Amit
If you have more idea about it, could you please help. Thanks |
September 3, 2010, 11:20 |
Pauli
What ignition model are you using? Have you tried to vary any of the parameters?
I was using EBU-LATC with 4-step ignition. I was able to make ignition delay & pre-mix phase vary significantly by changing the various parameters. |
September 3, 2010, 12:40 |
#9 | |
Amit
Hi, Until now, I have used Premixed with CFM, Unpremixed and Partially Premixed schemes with EBU STANDARD, LATCT and Modwall. Unpremixed and Partially Premixed seem to have no Ignition Delay. Premixed with CFM is mainly meant for HCCI and SI combustion. I really have to try something new now. What reaction scheme did you use? Thanks |
September 3, 2010, 13:48 |
Pauli
I am using Turbulent Unpremixed/Diffusion, EBU-LATC & 4-Step Auto-Ignition.
Are you trying to model a diesel engine? If so, why are you using unpremixed or partially premixed? That makes no sense. How are you defining ignition delay? I compare start of injection to initial rise in the heat release rate curve. With that definition I have 3-4 degrees delay in both my test data & simulation. |
September 3, 2010, 14:14 |
#11 | |
Amit
Hi Pauli, Partially Premixed doesn't make sense to me either. I was just trying to see what happens when I use that option. Other than that, Unpremixed is the one that I think I should be using either with Modwall or LATCT reaction type because of the one chemical reaction requirement of the 4-step Auto Ignition Model. Now coming to defining Ignition Delay, the way you are doing is what even I or anybody would do. i.e. by counting the no. of CAD for ID for any given fuel in the RHR graph of the real test and putting that value on 4-step autoignition model to imitate the nature of the graph or ignition. But the problem arises when you would like to simulate a new fuel with new CN that has not gone through experimental test. What I meant to say here is, I want to simulate a diesel combustion with fuel of known CN in Pro-star and come up with results that match the actual experimental test data. Is it something possible to do with Pro-star you think? Thanks |
September 3, 2010, 16:02 |
#12 | |
Amit
Also, what do you do with Tgradient and Start and End time? How do you setup Ignition Delay on 4-step Auto Ignition? |
September 3, 2010, 19:23 |
#13 |
Pauli
Calibrating a combustion simulation involves tuning the spray, combustion and ignition sub-models. It's all coupled and very non-linear. So until you've seen your model predict well over a range of conditions, you can not be sure about just how well its calibrated. (You could have gotten lucky!)
The end results is that if you take test data with two different CN fuels, you might not see similar changes in your CFD results. My feeling is that It depends on how well your original calibration was. In other words, your spray model may have been off & you inadvertantly compensated with some combustion or ignition parameter. What changed in the fuel to give it a different CN? Did that also change something which would impact the spray characteristics? If so, then you'll need to update your spray model tuning. |
September 3, 2010, 21:30 |
#14 | |
Amit
Thanks Pauli, It feels really great to share info when I come across somebody who is equally interested in the subject matter as I do. What you are saying is right as spray modeling does play a very important role in combustion modeling. This afternoon I was trying to use 4-step auto ignition but I got confused with how to adjust the start and end time of ignition in terms of crank angle degrees as the option I see is in terms of time only. Could you guide me a bit please? Also, what ignition temperature/sec should I use? About spray modeling I will let you know what I have so that you will have an idea as well. Thanks |
September 7, 2010, 12:46 |
#15 | |
Amit
Although I have been trying, I still don't have an idea on how to set Tgradient in 4-step Shell Autoignition. Also, how to set start and end time of the ignition in terms of crank angle degrees rather than in seconds. I would appreciate your help. Thanks in advance |
September 7, 2010, 14:08 |
#16 | |
Amit
Hey Pauli, If I am modeling a diesel engine, what should I use? Premixed or Unpremixed or what? Please help. Thanks |
September 8, 2010, 11:12 |
#17 |
Pauli
To enter values in crank angle, you need to tell prostar to use crank angle. That is done with the trelation command. Or in the Nav Center, it is under the first entry: Select Analysis Features -> Time Relationships. Note: The time relationships sub-panel is not active until you switch to transient mode.
Diesel engine is unpremixed. |
September 8, 2010, 12:47 |
#18 | |
Amit
Thank you very much man. In my case, I have been using time relationship in angle with transient mode fortunately but the problem is it is not firing. Okay, if I am running a case for which SOI is at 718 CAD (in prostar or 1 CAD before TDC in real engine), and the RHR trace obtained from the real test shows that the combustion starts 4 CAD after TDC. In such situation, what value should I enter in the start and the end boxes? In addition to this, the other problem I am facing is the TGRADIENT (K/s). Currently I am using the default value of 1.0e+06. I wonder if this is the right number to be entered in the TGRADIENT box !! Most importantly, if we are specifying the start of combustion using the start and the end boxes then it means that we are defining the Ignition delay. In such case how will the cetane number plays its role as this is what determines the delay. I have been trying different values but it is misfiring every time. I would appreciate your guidelines deeply. Thanks a lot. |
September 8, 2010, 13:51 |
#19 |
Pauli
The start & end of ignition boxes only tell the code when to activate the ignition sub-model. They have nothing to do with ignition delay. Set start of ignition crank angle to something just before start of injection. Set end of ignition to the end of your simulation or end of injection. Limiting the time the ignition sub-model is active is done to minimize computational overhead (no point checking for ignition when it can't/shouldn't occur).
The effect of cetane number is decribed in the methodology manual. See the section for the ignition model (equation 11-85 in the Star 3.26 manual). The default Tgradient value should work fine for initial runs. You can tune it later. |
September 8, 2010, 13:56 |
#20 | |
Amit
Thank you man. Let me try what you said and will get back to you very soon. Thank you once again. |
EDDY BREAK UP MODEL (COMBUSTION) | GACEM hatem | Phoenics | 2 | December 31, 2009 15:50 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
eddy break model using usrsrc routine | dj | CFX | 0 | October 14, 2003 00:15 |
regarding eddy break up model | dj | CFX | 0 | September 30, 2003 02:05 |
EDM and EBU combustion models. | cfd guy | CFX | 0 | September 4, 2002 07:13 |
