Home > Forums > CD-adapco
Cluster HP-MPI error.
Old   July 27, 2009, 06:32
Default Cluster HP-MPI error.
niceone is on a distinguished road
I bought 3 servers and one workstation. Iím trying to use my 3 serves as a cluster. I have installed Open Suse v11.1 and CD-Adapco 4 in all computers.
Thatís my set up:
And that's my error, it happens when I try to run the simulation with parallel hosts.
- Hp-MPI licensed for CD-adapco.
If someone had this error before and know how to solve it, I'll be very grateful.
Thanks a lot !
niceone is offline   Reply With Quote
Old   July 28, 2009, 14:32
Paul Hancock
Paulh is on a distinguished road
I also had a cluster mpi error recently. CD-adapco support suggested two things:
Use mpich by inserting 'put -mpidriver mpich' into the comand line. It's probably slower but who knows.
Put a link back to a previous ccm+ mpi folder into the current releases folder and then use something like -mpidriver hp2:"-prot -version 2.2.7". The directory structure should be similar to:
. . . /starccm+4.04.011/mpi/hp2/linux-x86_64-2.2.5/2.03.00.00
I went back to v3.06.006 and have a job running now.
. . . /starccm+3.06.006/mpi/hp2/linux-x86_64-2.2.5/2.02.07.00
Note that the -version is NOT 2.02.07.00 but 2.2.7.
I hope this helps.
paulh
Paulh is offline   Reply With Quote
Old   July 28, 2009, 19:57
f-w
f-w is on a distinguished road
You might also want to try to run the host on the local host, rather than on a worker host.
f-w is offline   Reply With Quote
Old   July 29, 2009, 03:39
Thank you°! It works with mpich.
I called to Cd-adapco support to ask what happen with hp-mpi.. and they told me that Suse 11.1 and this version of hp-mpi is not compatible. ""∑!"∑$$∑"%$%&% " they said that i have to use the '-mpi mpich' into the command line... the same as you told me...
Ty !
Old   October 1, 2009, 05:44
Thumbs up Problem Solved
Oliver Lauer
olauer is on a distinguished road
Right now I got an answer from CD-Adapco support to solve at least the same problem on my site.
It seems that there exists a entry
127.0.0.2 machinename
in /etc/hosts, which misleads HP-MPI.
If you delete this entry and put machinename to the correct IP address (if not already there) everything should be fine again (at least it worked here).
Good luck
Oliver
olauer is offline   Reply With Quote
Thread Tools
Trackbacks are On
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
