accessing current time
Dear all.
hi working with star-CCM+ i want to write a field function which uses current physical time. how can I access current physical time? thanx alot |
It is possible to access time using java or usercode (C, FORTRAN) The documentation how to compile and bind user code is actually pretty good. Read it and follow the instructions mentioned there.
The following files should do what you want, except that they are only updated while iterating. (Havent found a way to force an update yet) Code:
//filename = uclib.c Code:
//filename = physicaltime.c |
thanks Svenne. it was very helpful
