-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   Merging .pst files in parallel run (http://www.cfd-online.com/Forums/cd-adapco/77787-merging-pst-files-parallel-run.html)
Purushothama July 4, 2010 03:54
Hello dear starcd-colleagues,
Could you please anyone one tell me how to merge .pst files (obtained form different processors) in parallel run? I am using star cd 3.26 version and my geometry has about 1 million cells. Thanks in advance.
Pauli July 4, 2010 11:38
The 3.26 installation has an OS command line utility mergepst. Enter mergepst at the command line & answer the prompts.
Purushothama July 5, 2010 00:59
Dear Pauli,
Thanks a lot for your quick reply. I am sorry, I could not underastnd the method you mentioned. Could you please elaborate this little bit more. And also can you tell me how to merge the pst files while it is still running, if I want to check the results in between (before convergence). Thanks again.
xamo July 7, 2010 03:58
during the calculation you may enter the command "star -chkpnt" in the directory you started the calculation. The last saved post files on each machine will be merged in one post file in a new directory.
After the calculation:
In the directory:
/starcd/v3260/STAR/3.26.xxx/linux64_2.4xxx/bin
you can find a file called mergepst.
Copy this file to your directory where you started the calculation and start ./mergepst and answer the prompts as Pauli mentioned.
Regard
xamo
Purushothama July 7, 2010 22:22
I did it. Thanks a lot to all. Have a nice day.
mutu26 July 21, 2010 09:09
I often work with pst files. But several days ago I noticed an unusual problem in my MS Outlook. Or more exactly all my emails were lost. I lost my head. But unexpectedly my friend phoned me and told about many interesting things, one of them was - opening .pst files. I tried it and was glad, because the program solved my issue fast and easy as far as I remembered. Moreover I saw the application converted my mailbox to separate files or to a file of PST format.
