July 4, 2010, 04:54 |
Merging .pst files in parallel run
Purushothama Chippar
Rep Power: 15 |
Hello dear starcd-colleagues,
Could you please anyone one tell me how to merge .pst files (obtained form different processors) in parallel run? I am using star cd 3.26 version and my geometry has about 1 million cells. Thanks in advance. |
July 4, 2010, 12:38 |
Pauli
Rep Power: 17 |
The 3.26 installation has an OS command line utility mergepst. Enter mergepst at the command line & answer the prompts.
July 5, 2010, 01:59 |
Rep Power: 15 |
Dear Pauli,
Thanks a lot for your quick reply. I am sorry, I could not underastnd the method you mentioned. Could you please elaborate this little bit more. And also can you tell me how to merge the pst files while it is still running, if I want to check the results in between (before convergence). Thanks again. |
July 7, 2010, 04:58 |
Rep Power: 17 |
during the calculation you may enter the command "star -chkpnt" in the directory you started the calculation. The last saved post files on each machine will be merged in one post file in a new directory. After the calculation: In the directory: /starcd/v3260/STAR/3.26.xxx/linux64_2.4xxx/bin you can find a file called mergepst. Copy this file to your directory where you started the calculation and start ./mergepst and answer the prompts as Pauli mentioned. Regard xamo |
July 7, 2010, 23:22 |
Rep Power: 15 |
I did it. Thanks a lot to all. Have a nice day.
files, merge, parallel computation, pst |
Display Modes | |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
parallel run for fsi simulation??? | smn | CFX | 2 | July 19, 2009 05:04 |
Serial run OK parallel one fails | r2d2 | OpenFOAM Running, Solving & CFD | 2 | November 16, 2005 13:44 |
How to run parallel in ICEM_CFD? | Kiddo | Main CFD Forum | 2 | January 24, 2005 09:53 |
to do a run in parallel mode with star_hpc | massimo | Siemens | 4 | January 30, 2003 09:33 |
