August 3, 2010, 14:39 |
Polyhedral Optimization
Matt Lynam
Rep Power: 15 |
I am having a strange issue and I'm wondering if anyone else has come across this problem. When I create my volume meshes with the polyhedral mesher and optimization checked, the mesh generation typically stalls (for hours) during the optimization portion. I typically disable the optimization now when generating my meshes. Anyone else having this problem?
Thanks, ML |
August 6, 2010, 11:21 |
Rep Power: 15 |
Mlynam,
I have had the same problem as well (using Star CCM+ v1.3). It appears as if it is stalled, however, it is not. The CPU Processor shows that the program is running. I let it run over night and in the morning, the mesh was optimized. I too disable this or let it run overnight if I can afford the time. |
August 6, 2010, 11:26 |
I build polyhedral meshes almost every day and I did not notice that the optimization phase takes hours. I wonder what version of the code you are using and more over what kind of meshes you are building. The only reason I can think of why the optimization phase should take a very long time is when the polyhedral mesh for some reason has a very large number of low quality cells.
S.P. |
polyhedral cells | bill | Main CFD Forum | 10 | March 11, 2014 06:52 |
[ICEM] When will Ansys introduce polyhedral meshing? | jsm | ANSYS Meshing & Geometry | 5 | November 13, 2013 04:41 |
Polyhedral in parallel | drdr18 | FLUENT | 5 | April 3, 2009 17:56 |
BOOK ON OPTIMIZATION OF FORTRAN CODES | Alberto | Main CFD Forum | 3 | November 10, 2008 06:07 |
Polyhedral meshes in STAR-design | Lee | Siemens | 3 | March 10, 2005 16:43 |
