September 22, 2007, 09:32 |
Diesel combustion simulation
Hi everybody, I'm looking for a combustion simulation in a Diesel engine...
Since now I've tried to use epthane, dodecane and a mixture of dodecane and esadecane... what mixture do you use for simulations like these? And also...have you got some information about Diesel fuel properties? Such as relations of viscosity vs temperature, density vs temp,... Thanks in advance |
September 25, 2007, 20:28 |
Re: Diesel combustion simulation
noone can help me about this?
October 16, 2007, 09:17 |
dear andrea
i also try to do this......... unfortunately no help.... best regards can we make a colaboration? |
October 16, 2007, 22:07 |
Well if you want we can...I'm trying to find the "best" set of models for ECFM3Z model...what are you looking at? And what king of fuel do you use? Thanks in advance! (I've see you're starting...I suggest to look carefully at the metodology it you're going to use some standard model...and try to vary the models used to see the differences in results!)
October 16, 2007, 22:10 |
emh...some I've made some mistakes in writing...I would write what "kind" of fuel you use and to look carefully at the metodology if...
November 22, 2009, 23:32 |
ramaiah
sir,
sorry instead of reply I am begging help for my work. I am doing simulation on diesel engine , I am in need of pdf for dodecane could you plz help me in this regard.please help me through email balakshowry@yahoo.com as I am unable to access fluent forum.waiting for your valuable reply. Bala showry |
December 9, 2009, 20:42 |
Rep Power: 16 |
Hi Andrea,
We want to use detailed kinetics to simulate combustion process. ECFM3Z model is good, but it uses reduced chemical kinetics mechanisms for fuel oxidation. If you compare detailed mechamism and reduced mechanism still there is a great difference. With the increasing power of computers it will be possible in the future to simulate detailed chemistry coupled with turbulence. Regards |
December 10, 2009, 13:43 |
Pauli
Rep Power: 17 |
www.convergecfd.com
August 21, 2010, 08:16 |
need help
#9 |
Alexandru
i'm new around here and novice in this kind of stuff. i'm interested on a program for a 4 stroke diesel combustion simulation. I heard about Fluent 6.3 - and that is very hard to work with - and Ansys 12 (Ansys 11 can offer the possibilty of combustion simulation). thx in advance for any advice, Alexandru |
Display Modes | |
Diesel Combustion with DPM simulation | Kamil Sobczak | FLUENT | 2 | March 29, 2016 05:58 |
DIESEL COMBUSTION | Benzamia | FLUENT | 8 | January 22, 2012 01:33 |
Diesel combustion simulation ( Heat release rate) | venkatesh | Siemens | 2 | April 29, 2009 08:38 |
diesel combustion | Marco | FLUENT | 0 | September 14, 2005 09:27 |
diesel combustion | zahir | FLUENT | 2 | October 11, 2002 06:48 |
