License server info- where is it stored?
I have just installed Star-CCM+ on my PC. However, during installation I entered one of the license server addresses incorrectly, and (despite re-entering it correctly) it seems to be causing problems. Namely, Star-CCM+ is unable to acquire a license at the start of a new simulation. I've tried uninstalling and reinstalling, but the license server info is left unchanged. Therefore, I need to find where it is stored in order to edit or delete it. I've looked in the Registry (HKLM\SOFTWARE\FLEXlm License Manager\CDLMD_LICENSE_FILE) and in the Environment Variables, but these locations only hold the three correct license servers. It is the incorrect one which I am unable to locate. I'd be extremely grateful for any input on this. Thanks :) |
Just adding a bit more info if needed- here's the contents of the License Server Information stage during installation:
A scan for license server hints found: Registry Entries (HKLM\SOFTWARE\FLEXlm License Manager):A check for server accessability found: [Valid Server 1] -(Obviously I've replaced the actual server addresses) Thanks |
In case someone stumbles over this while googling.
On Linux the license sever info is stored in $HOME/.flexlmrc You can also set the environment variable CDLMD_LICENSE_FILE by prepending, via export or in your bashrc. Best, Hendrik |
