Home > Forums > CD-adapco
mrf doesn't work
Old   January 7, 2011, 05:03
Default mrf doesn't work
armansyah
armand is on a distinguished road
hi,
my mrf model does not work, I use multiple frame-implicit method. this is occur when I apply inlet boundary. in the output file there are some "warning 003 (fluid inflow detected)".
but if i modeling my case without inlet boundary no problem with my mrf, mrf successfully modeled.
thank you for your response
armand is offline   Reply With Quote
Old   April 1, 2011, 18:46
ara
ara1362 is on a distinguished road
if you are just modeling MRF, then you should have 3 regions, region 1 would be where you specify the inlet condition, interface the other end to the upstream of the MRF, and then interface the downstream to the third region where at the end it pressure outlet.
good luck.
ara1362 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Should an empty MRF zone really induce this much cross-flow? sylvester OpenFOAM 5 November 18, 2010 04:48
How to work with constant pressure? Martin CD-adapco 2 February 25, 2009 14:23
Getting FoamX to work shaun OpenFOAM Installation 12 March 23, 2007 09:55
Why do the Plant library cases don't work? Alumna Phoenics 6 June 22, 2004 12:08
why my In-Form doesn't work? green Phoenics 2 May 27, 2004 21:03
