Home > Forums > CD-adapco
how to setup 3d wind tunnel
Like Tree1Likes
  • 1 Post By bukm
Old   January 13, 2011, 07:37
Default how to setup 3d wind tunnel
bu
bukm is on a distinguished road
need help in setting up wind tunnel. do i need to prepare the wind tunnel in a cad software or i can setup in star ccm+?. how to prepare the mesh for the wind tunnel with an object inside it? please help me. i am still new in cfd. regards.
bukm is offline   Reply With Quote
Old   January 13, 2011, 08:59
webceo89 is on a distinguished road
In Star-CCM+ you dont need do generate the wind tunnel in CAD.
After importing your Testing geometry, you can create a block surface around your body. If you want to model the half windtunnel, you can enter the dimensions of it and then use the function "substract" to receive a closed volume.
webceo89 is offline   Reply With Quote
Old   January 14, 2011, 02:47
bu
thanks i will give it a try. if u dont mind, could you please write the steps? thanks.
Old   January 14, 2011, 03:35
bu
i managed to setup the surface block. however when meshing the block and the object inside the block, the object inside the surface block was lost. how do i define the block to work as a wind tunnel and the object as a solid object in star cmm. please provide some tutorial. i am trying to do the simulation in 3d. Regards
Old   January 14, 2011, 03:45
To help you out in detail, please send me a pm with your email...
Old   January 14, 2011, 03:55
bu
ok check ur pm.
Old   January 14, 2011, 04:02
bu
update screenshot
Old   December 13, 2014, 15:35
hwsv07 is on a distinguished road
can someone help on this?
I faced the same problem.
[QUOTE]
[\QUOTE]
hwsv07 is offline   Reply With Quote
Old   December 13, 2014, 15:36
I have a geometry of my specimen that I want to test. I placed a rectangular block over my specimen and my specimen was lost in the block.
Old   December 13, 2014, 16:06
SB123 is on a distinguished road
check the user manual, for the tutorials see the below link assuming you've installed star in the default location. the below tutorial show's how to do it in great detail.
Tutorial Guide > Motion > Marine Resistance Prediction: KCS Hull with a Rudder > Mesh Generation > Creating the Towing Tank
with that being said, the user manual is your friend, use it for all its worth... it's probably best to start there before you start posting threads on here looking for people to solve your problem for you
SB123 is offline   Reply With Quote
Thread Tools
Trackbacks are On
flow in cyclic wind tunnel yogesh@cfd Main CFD Forum 0 November 8, 2010 05:28
how to consider perforated wind tunnel wall in CFD simulation littlelz CFX 4 June 11, 2009 05:51
Simulating a G├Âttingen type wind tunnel in FLUENT Chris FLUENT 3 December 4, 2006 18:33
Virtual Wind Tunnel in FLUENT ND FLUENT 0 April 7, 2006 07:43
Wind tunnel modeling Pandu CFX 3 May 19, 2003 21:49
