-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   Memory segmentation fault on CentOS 5.5 (http://www.cfd-online.com/Forums/cd-adapco/84159-memory-segmentation-fault-centos-5-5-a.html)
Bauer January 21, 2011 10:57
I have installed STAR-CCM+ 5.06 on a fresh CentOS 5.5 install.
The installation seemed to go ok, but trying to create (or open) a project causes segmentation fault.
The output in StarCCM+ shows:
Starting local server: /opt/starccm/starccm+5.06.010/star/bin/starccm+ -server
/opt/starccm/starccm+5.06.010/star/bin/starenv: line 1253: 17329 Minnesegmentsfeil      "$@"
No information is dumped to the terminal.
I have tried serial and parallell processing, but nothing works.
Any ideas?
Edit:
/var/log/messages:
Jan 21 15:39:52 dhcppc1 kernel: star-ccm+[15800]: segfault at 0000000000000000 rip 00002b2fe31bd606 rsp 00007fff036353d0 error 4
Jan 21 15:41:42 dhcppc1 kernel: star-ccm+[16276]: segfault at 0000000000000000 rip 00002b5971334606 rsp 00007fffe9353a60 error 4
Jan 21 15:42:50 dhcppc1 kernel: star-ccm+[16473]: segfault at 0000000000000000 rip 00002ba636c26606 rsp 00007fffab8a5b80 error 4
Jan 21 15:44:49 dhcppc1 kernel: star-ccm+[16891]: segfault at 0000000000000000 rip 00002b6ac1ae8606 rsp 00007fffe48feba0 error 4
Jan 21 15:46:50 dhcppc1 kernel: star-ccm+[17329]: segfault at 0000000000000000 rip 00002ac3b3d18606 rsp 00007fff3737b990 error 4
rwryne January 21, 2011 14:04
Try running memtest86+ and seeing if you get any memory errors...
Bauer January 21, 2011 19:52
30 minutes of memtest86+ shows no errors, however I will run a more extensive test tomorrow.
If it is of any relevance, now I noticed this getting dumped to the terminal while starting starccm+
java.net.UnknownHostException: Bauer: Bauer
        at java.net.InetAddress.getLocalHost(InetAddress.java:1354)
        at org.netbeans.CLIHandler$1.run(CLIHandler.java:559)
        at org.openide.util.RequestProcessor$Task.run(RequestProcessor.java:602)
        at org.openide.util.RequestProcessor$Processor.run(RequestProcessor.java:1084)
Edit:
Another 2-hour test gives no errors.
Bauer January 23, 2011 13:38
Turns out it works without problems on Ubuntu, so never mind :)
JBeilke January 25, 2011 09:33
I had to install my new machine (i7-2600) and tried different Linuxes. Here are my observations:
Ubuntu 10.04: ccm+ works but very slow, starcd crashed
Suse 11.3: ccm+ crashed (as described above) but starcd workes and also fast
Suse 11.1 and 11.2: both codes work and also with the expected speed.
rwryne January 25, 2011 12:43
Suse 11.3: ccm+ crashed (al described above) but starcd workes and also fast
Can you give a bit more info on your "study" specifically on Ubuntu? How much slower was ccm+? Was it just slower loading, meshing, when solving, or everything?
Thanks for info
JBeilke January 26, 2011 11:22
Ubuntu was about half the speed compared to Suse running on 1 and also on 2 cores. Probably something went wrong with the installation. But since StarCD (v3 and v4) did not really run I did not try to resolve the other problem.
