Crack check problem
Old   September 15, 2005, 11:12
Default Crack check problem
Tunc
Hello everbody,
I´m working on a 3D airfoil. I`ve generated the mesh with ICEM then exported it to StarCD using CGNS format. During the crack check I´ m getting nearly 2500 cells with cracks within 48000 cells. I´ m using a crack limit smaller than my thinest cell edge. On the other hand when I observed these 2500 cells with eye, I couldn` t see any visual defects. What could be the reason for this problem?
Tunc
Old   September 15, 2005, 12:41
Default Re: Crack check problem
HADD
Why didn`t you use the direct export form ICEM to STAR-CD?
Old   September 16, 2005, 03:11
Tunc
Actually, I´ ve done it also. But the number of the cells with cracks was the same.
Old   September 16, 2005, 03:33
HADD
I can suppose, that these "crack" cells are the most thin in your model. If it is actually so, than the reason of your problem is too small relation of length cells to its height . But in practice, for my experience, it doesn't influence on solution field. You can save geom file and begin to calculate.
Old   September 16, 2005, 03:38
Tunc
You` re right Hadd. I` ve cracks within these cells. I` ll try it. Thank you...
Old   September 16, 2005, 07:57
bv
i think , if u have cracks in the model, it will not write the Geom File. check it.
BV
Old   September 20, 2005, 11:06
Ant
When you go to Check grid, then select check option Cracks, then try reducing delta. I've had this problem too.
Old   March 16, 2011, 00:06
gagi is on a distinguished road
hii after reducing delta even we save model and run, the delta value wont be the new value and it still indicates cracks.. what should i do?
gagi is offline   Reply With Quote
Problem with 2D ICEM mesh check in fluent Nicola FLUENT 3 March 25, 2013 05:56
found crack in prostar but no crack in CCM+ ?? Ingear Siemens 4 October 23, 2006 09:37
Cell check and Boundary check errors AB Siemens 4 October 28, 2004 13:04
How do I check whether moving mesh problem can be Harendra Siemens 0 October 28, 2004 09:52
How to crack this problem Lee Siemens 2 September 12, 2003 10:40
