Home > Forums > CD-adapco
Particle-Laden Flow Tutorial
Old   May 10, 2011, 16:00
Default Particle-Laden Flow Tutorial
alan81 is on a distinguished road
Dear all,
I have a question related to Particle-Laden Flow Tutorial. in this tutorial the star-ccm+ partially blocked elbow duct is used to simulate Particle-Laden Flow. i do not know how to find that in which way the duct geometry was created, i want to know if that duck is solid or has thickness.
because i am going to simulate in Particle-Laden Flow in pipe so do have to create a solid cylinder (one circle and extrude it) or as pipe has a thickness ( two circle subtract them and then extrude it ).
Thanks for your help
alan81 is offline   Reply With Quote
Old   May 10, 2011, 17:55
f-w
f-w is on a distinguished road
That particular duct is a solid. Unless you are modeling heat transfer through the wall, then geometric wall thickness is not required.
f-w is offline   Reply With Quote
Old   May 11, 2011, 03:25
Thanks f-w
in my case i want to model the erosion in pipe which liquid( oil) and sand are inside the pipe, do i have to create a solid geometry of pipe or creating a pipe with specific thickness??
kind regards,
alan
Old   May 11, 2011, 11:45
f-w
Create a solid pipe (the wall of which will be representative of the inner wall).
Old   May 11, 2011, 11:48
Dear f-w
Thanks for your respond, one more thing, how can i chose the material for the pipe?? is that possible to choose the martial of the pipe??
many thanks
Old   May 11, 2011, 16:46
f-w
I suggest you go through the "Modeling Erosion" tutorial, it should answer your questions.
Modeling Physics > Modeling Multiphase Flow > Using the Lagrangian Multiphase Model > Working with Lagrangian Phase Models > Modeling Erosion
Old   May 11, 2011, 18:00
Hi again,
thanks for your suggestion f-w. yes its written that the erosion depends on the type of the wall material. when you choose the model of erosion, there is a material particle in the model but still i can not find the material of the wall. and i am not sure if Bai-Gosman that is what i am looking for or not.
have a nice time
Old   May 11, 2011, 19:18
f-w
The wall material is taken care of using coefficients specified by the user in the erosion models. More info in: Modeling Physics > Modeling Multiphase Flow > Using the Lagrangian Multiphase Model > Formulation > Erosion
I found a good tutorial for you to follow: Training Guide > Multi-Phase Flow Tutorials > Solid Particle Erosion Tutorial
Old   May 13, 2011, 04:15
Thanks f-w
I still can not find where i have to change the material of the pipe itself. Do you know where i should change it??
Thanks
Old   May 17, 2011, 09:37
Ryne Whitehill
rwryne is on a distinguished road
Originally Posted by alan81 View Post
Thanks f-w
Thanks
Expand Continua->Expand your Solid continua->Expand Models->Expand solid. It defaults to Al, right click and hit replace with.
rwryne is offline   Reply With Quote
Old   May 17, 2011, 11:48
Thanks rwryne for your answer, now its clear that the al is chosen as a default martial for the the pipe.
thanks again
Old   May 17, 2011, 13:41
hi rwryne,
but according to the tutorial that is the properties of the solid particle which entrained in the liquid which is written in the tutorial ((Sand particles are entrained in the liquid flow in this simulation and so the density of the Lagrangian phase must be set to the density of sand-- In the Continua > Physics 1 > Models > Lagrangian Multiphase > Lagrangian Phases > Phase 1 node, open the Models > Solid > Al > Material Properties > Density node and select the Constant node.))
so if that is the properties of particle, where should we change the properties of the pipe( in the tutorial is duct)
best wishes
Old   May 17, 2011, 13:43
those information are written in solid particle particle erosion tutorial
Old   May 17, 2011, 14:45
Ryne Whitehill
hi rwryne,
best wishes
I looked at this tutorial: you are not actually modelling the pipe in it (i.e. no mesh is being generated to represent the volume of the pipe, only of the surface). The pipe's material properties are being set on the wall boundaries within the fluid continua.
See this page in the help: Training Guide > Multi-Phase Flow Tutorials > Solid Particle Erosion Tutorial > Setting Lagrangian Phase Boundary Conditions > Setting the Erosion Model
specifically:
When modelling erosion using CFD methods, it is necessary to select an erosion model based on a knowledge of the material undergoing erosion and the conditions under which the erosion is taking place.
Thread Tools
Trackbacks are On
Question from tutorial: Buoyant flow in a partitioned cavity noppawit CFX 13 March 19, 2014 03:18
Modifying the "Transonic Flow over an Airfoil" tutorial for supersonic flow? darrenn STAR-CCM+ 2 November 8, 2012 16:44
particle tracking in unsteady flow peterchen FLUENT 1 July 22, 2010 22:18
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
Particle mass flow rate Jeff CFX 3 September 17, 2004 10:46
