Divergence problem running a DFBI
Old   September 20, 2011, 04:23
Default Divergence problem running a DFBI
satriani is on a distinguished road
I'm trying to simulate the behaviour of a propeller thrusted airplane using Superposed Rotation. My geometry is composed by sub domain containing a propeller and a main domain containing the aircraft and this sub-domain. The reason for the sub domain is that the mesher doesn't have to re-do the mesh for every rotation in all the space but only in the sub-domain containing the propeller. The problem i encounter is that my simulation diverge. Someone can help? thanks in advance
additional info
the propeller is rotating at 10000 rpm and time step is 1 x e-04
satriani is offline   Reply With Quote
Problem with viewing graphic view when running in UNIX pitisrisuk Main CFD Forum 1 April 15, 2016 11:39
RSH problem for parallel running in CFX Nicola CFX 5 June 18, 2012 18:31
Problem with running FoamX in a distributed environment susana OpenFOAM Pre-Processing 1 March 28, 2007 17:11
Divergence problem on different meshes Harry Main CFD Forum 2 September 26, 2006 00:23
Problem running FINE Turbo Michal Vanco Fidelity CFD 0 June 7, 2004 06:58
