Mesh repair
Old   October 22, 2008, 13:11
Default Mesh repair
Wei
After converting an old mesh created using STAR-CD 3.1 to STAR-CD 4.06 by using nastran format, there are holes at particular part of mesh.
Does STAR-CD 4.06 provide any function particularly to repair such meshing problem?
Thank you.
Old   October 23, 2008, 07:28
Default Re: Mesh repair
allan
Hi
What do you mean by holes?
Old   October 23, 2008, 08:44
whitemelon
Does the mesh has couple? nastran format doesn't support the couple mesh.
Old   October 23, 2008, 10:12
TG
Why don't you just read/resume the 3.1 .mdl file directly into 4.06? Nastran does not understand all possible cell shapes that STAR is capable of producing. The holes might be from that.
Old   October 24, 2008, 06:10
Wei
Hi Allan,
please see the figure http://www.whlam.com/engine/corruptedduct1.gif
There are missing cells at particular region forming some holes.
Old   October 24, 2008, 06:29
Wei
The reason I choose nastran format is due to the saving problem of old STAR_CD 3.1 .mdl mesh in the STAR-CD 4.06. The resumed STAR-CD 3.1 mesh can not be saved using STAR-CD 4.06. To secure the STAR-CD 3.1 mesh, I therefore exported through nastran format.
It is strange. The problem of holes or more precisely the missing cells still occurs when read the .mdl file directly.
Yes, there are couple settings. Unfortunately I lost the couple settings as well.
Could you share what particular cells nastran format does not support?
Old   October 24, 2008, 06:36
Balduin Bankerotti
The missing cells are trimmed cells which can are not supported within the nastran format.
Old   October 24, 2008, 06:45
Wei
Should be. The trimmed cell is not widely supported by the standard file format.
In this case, any suggestion to repair it or do you think exporting the geometry and then recreating the entire mesh is a better solution?
Thank you.
Old   October 24, 2008, 10:45
Pauli
NASTRAN does not support trimmed (polyhedral cells). It supports tetrahedron, hexahedron and prism cells.
Here is something you can try. In Star 3.1, use the cdsave command to export the model. In Star 4.06 use the ifile command to read in the model. I'm not sure what happens with the Star 3.1 couples. (Star 4.06 is a face based code which does not use couples.) Star 4 may do the necessary conversion. Sorry but I haven't used Star 4 much so I'm not sure about this matter.
Old   October 24, 2008, 12:33
TG
I think exporting the geometry and recreating the mesh is a much better idea. The new trimmed/poly meshers in pro-STAR4 are borrowed from STAR-CCM+ and produce significantly better meshes than older version of STAR3.
Old   October 24, 2008, 15:00
  #11
Balduin Bankerotti
Read the mesh into v4 and run the command "cptran". Look if the holes are still there and post the warnings/errors from the output window.
Old   October 24, 2008, 15:02
  #12
Balduin Bankerotti
Read the *.mdl file !!!
Old   October 24, 2008, 19:58
  #13
whitemelon
why not export the *.cel and *.vrt data?
Old   October 27, 2008, 04:09
  #14
Anton Lyaskin
Because even *.cel file format was changed between 3.x and 4.x version.
Many, many thanks to CD-Adapco...
Old   October 27, 2008, 06:40
  #15
Balduin Bankerotti
v4 can read the cell files from v3. But with exporting just *.cel and *.vrt you will loose the couples which are there in most proam meshes.
How would you support polyhedral cells without a possibility to write them to the *.cel file? There are also tools available to convert a v4 *.cel file back into v3 format just ignoring the polys.
Old   October 27, 2008, 11:14
  #16
Wei
cptran does seem the right answer to repair the missing cells.
1) I read the v3.1 .mdl file; 2) cptran the mesh (fix the missing cells) ; 3) export as .cel, .vrt and .bnd files (resumed v3.1 .mdl can not saved directly in v4.06); 4) import to v4.06
However, when i check the mesh quality, there are some other error messages.
errornumber-command-description
69-chec- non-right-handed cells found
234-chec- cell has a greater-than-desired aspect ratio
176-chec- cells found with face warpages greater than the prescribed value
80-chec- internal face angle of a cell exceeds prescribed value
70-chec- cells found with negative volume or volume less than specified volume
406-chec- centroidal check failed. cells have centroids which reside outside their volumes.
71-chec- centroidal check failed. cells overlap.
74-chec- there are cracks (unconnected regions) in the model
265-chec- model has groups of disconnected cells.
76-chec- cell faces with very small suface areas found in the model.
Are these fatal errors or ignorable?
Old   October 27, 2008, 15:43
  #17
Balduin Bankerotti
What are you doing man? You should simply take the v31 *.mdl file and read it into v406. After that you type the command "cptran all". Then there should be no holes or missing cells.
I tried it myself with an old proam mesh and it worked.
Check if there are any warnings or errors during this process and post them.
Forget the *.cel and *.vrt files!!!
Old   October 28, 2008, 03:11
  #18
Anton Lyaskin
BTW, what are these tools? Because sometimes I really miss such an opportunity
Old   October 28, 2008, 03:40
  #19
Cloud
I agree to TG. Live the surface from 3.1, then regenerate new trimmed meshes in 4.06. Trimmed cells of v3 and v4 are quite different. Another choice, you may try to resume 3.1 to 3.26, then resume 3.26 to 4.06. But this method may not work...
Old   October 28, 2008, 03:45
  #20
Balduin Bankerotti
Ask the support for the file "cell423.f" or search for star-backport.
Repair Wall Distance Error asd FLUENT 1 July 29, 2011 12:36
repair surface laura CFX 0 December 29, 2008 05:07
Surface Repair for Meshing Andy R Main CFD Forum 13 May 3, 2008 14:33
how to repair geometry by another way Priscila CFX 4 August 2, 2007 11:43
Cells repair Julie Polyakh Siemens 1 August 2, 2003 05:20
