[Sponsors] | |||||
Rep Power: 0 ![]() |
suggestions needed for my current simulation. I am currently running a heat transfer and flow model. There is mass flow inlet and heat sources and mesh is fine enough. I can run either flow or thermal model by deleting the other regions, but cannot run the entire model. Solver stops saying AMG solver diverged or floating point exception. Couldn't get much help from support. Can anybody advice me on this issue. Thanks in advance. |
Rep Power: 3 ![]() |
Some more information about your simulation model would be helpful to identify potential causes for your problem.
Providing you are using segregated solvers, try to decrease the underrelaxing factors. |
@willimanili thank you for the reply.
I am using segregated solvers and I have tried decreasing the under-relaxation factors but it doesn't change anything. I have tried several things like, I added some some initial conditions obtained from cold flow model, fluid velocity, temperature. Unfortunately, nothing has changed. Thanks |
If you simulate steady state, try this one:
Freeze the energy solver since the solution for the flow is nearly converged. Than unfreeze the solver at really low underrelaxing factors (<0.1). You can increase them manually step by step to get an faster convergence. If this also doesnt work check the mesh for mesh quality. Especially at the locations where the first pressure or temperature limit overstepping take place. |
Rep Power: 4 ![]() |
In CCM+ 5.04 it's impossible to use segregated solver when you have at least 2 regions (fluid and solid) connected by an interface. Conjugate heat transfer requires coupled solver to be activated.
#6 | |
Lucky Tran
Rep Power: 6 ![]() |
You are mixing up terms. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| a CFD software is needed... | maxgzc | Main CFD Forum | 3 | September 27, 2011 01:51 |
| Mesh generation software is needed | H.Dou | Main CFD Forum | 12 | May 4, 2011 15:20 |
| attachDetach: Not all zones and patches needed in the definition have been found. | schmittp54 | OpenFOAM Running, Solving & CFD | 2 | October 20, 2010 09:26 |
| a dissertation in ETD needed very much | LiQiang | Main CFD Forum | 0 | March 11, 2005 03:09 |
| CFD Software Engineer needed in Fort Worth, Texas | Ross | Main CFD Forum | 0 | November 19, 2001 14:48 |
