[Sponsors] | |||||
Jyothiprakash
Rep Power: 0 ![]() |
hi..i am fresher for CFD..what is the solution for error..Gamma ReTheta Transition Model must have valid field function set for free stream edge definition..
Joshua Counsil
Rep Power: 5 ![]() |
You must define the freestream edge so that the freestream momentum thickness Reynolds number can be transported into the boundary layer.
Create a field function (Tools > Field Function). Define the field function. The Help file of CCM+ uses this as an example:$WallDistance > 0.005?1:0 (if the wall distance is larger than 5 mm, then that is the freestream; otherwise, it's the boundary layer). In Continua > Physics > Models > Gamma ReTheta, set the Free Stream Edge to your user-defined field function. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 17 | August 22, 2009 03:59 |
| Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
| transition onset - SST:Gamma Theta Model | Prad | CFX | 4 | February 21, 2007 09:32 |
| where to set CFX Transition Model? | steven | CFX | 6 | January 17, 2007 11:19 |
| k-e model in transition flow | Qi Yuan | FLUENT | 0 | January 25, 2001 03:14 |
