Field Function Question. Need help writing it :(((
Old   February 6, 2012, 16:44
Question Field Function Question. Need help writing it :(((
kj878
kj878 is on a distinguished road
So I'm fairly knew to StarCCM and I need to set up my initial wall temperature such that it decreases as it goes along the length. I believe i need to write a field function for this but unfortunately I have zero experience in writing programs/codes and I have no idea how to write field function formula for my problem.
Wont someone be kind enough to help me write a field function?
My problem statement is a fluid flowing through a pipe, length say 1m and the temperature of the wall varies through the length.
From L=0 to L=.5 I need my wall temp to be at 150C. From L=.5 to L=.75, the wall temp needs to drop from 150C to 70C, linearly. Similarly, from L=.75 to L=1m, the wall temp needs to drop from 70C to 35C, linearly as well.
Can someone please help me with this??
Many thanks in advance!
kj878 is offline   Reply With Quote
Old   February 14, 2012, 18:30
Thomas Ziegenhein
ThomasZiegenhein is on a distinguished road
Another option is to create an extern Table and read it in Star-ccm+.
With Field Functions it should work also. You get the values of the standard Field Functions through their names, e.g. $$Position[0] gives the i-th coordinate (x in Cartesian). IF-ELSE is like the short form in java, (Expression) ? statement1(if true) : statement2(if false) . You can make the linear drop in an extra Field Function and use it as statement. For further information take a look in the help.
ThomasZiegenhein is offline   Reply With Quote
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 08:53
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
user field function girishg STAR-CCM+ 5 May 13, 2010 09:21
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Question about wall function Gary Main CFD Forum 1 December 3, 2007 10:54
