Home > Forums > CD-adapco
How to extract an internal volume in star ccm?
Old   February 8, 2012, 06:48
Default How to extract an internal volume in star ccm?
Ke Wu
itsme_kit is on a distinguished road
Hi
I want to extract an internal volume for simulation
Can I do it in star ccm?
Thanks
itsme_kit is offline   Reply With Quote
Old   February 8, 2012, 07:16
willimanili is on a distinguished road
Yes, you can. There are several ways how you can do this.
One way is to load your geometry either in CAD-modeler or as parts. If your geometry consists of more than one body/part unite them with boolean operation. Because later on you will use the split by surface topolgie operation which can be just operate on one single part. Now assign your bodies to parts if you havent imported your geometry as parts. Launch the surface repair tool and fill all holes which define your internal volume (inlets and outlets). Go back to parts level and execute the split by surface topologie command. If all has been successfull you will now have two parts, the internal volume and your geometry part.
willimanili is offline   Reply With Quote
Old   February 8, 2012, 07:58
Ke Wu
Hi willimanili
I still can not do it in right way
Can you help me extract it?
Old   February 8, 2012, 09:19
Where exactly is the problem?
Old   February 8, 2012, 09:46
Ryne Whitehill
rwryne is on a distinguished road
Originally Posted by itsme_kit View Post
Hi willimanili
I assume your part is a solid body an d you are wanting the internal volume of it, lets say just a simple pipe.
1. Import it as a part into STAR.
2. Using the "surface repair tool" (right click the part, repair surface), fill the holes at the inlet and outlet of the pipe.
3. Right click on Mesh Operations and do New->Extract Volume
4. For input parts, select all the parts of the pipe
5. For volume options, change Mode to Surface then for Volume Surfaces, select your inlet surface
6. Select okay, you should have a volume representation now
edit: I am also assuming you are using a recent version of STAR. The mesh operations were added in 6.04 I think
rwryne is offline   Reply With Quote
Old   February 8, 2012, 12:29
Ke Wu
Hi rwryne
I think at present I have extracted the internal volume
Is the extracted volume a solid or hollow body?
How can I mesh the extracted volume?
Thanks
Old   February 8, 2012, 12:39
Ryne Whitehill
Hi rwryne
Thanks
When in the geometry phase, all things will be "hollow". Thinking like this is an artifact of using CAD software...in STAR-CCM, everything is a surface until you make a volume mesh.The real way to think of it is that your surfaces in STAR are going to be the boundaries for the volume mesh.
If you have the internal volume extracted then:
(Really broad steps, read the help to get more info on these)
1. Set up your mesh continua
2. Right click your Part, then click Assign Part to Regions , and click New Region.
Old   February 8, 2012, 14:58
Ke Wu
Does it mean the the region I creaded will be a solid body?
Old   February 8, 2012, 15:35
Ryne Whitehill
Again, there really is no "solid body" in the STAR-CCM+ environment. There is a volume mesh, which you create from the regions.
Once you get your regions set, and your mesh continua set up, hit generate volume mesh.
Old   February 8, 2012, 15:52
Read this thread maybe it helps your understanding. Especially the second post from abdul
Old   February 16, 2012, 11:58
Ke Wu
so far i can successfully extract the volume from a single part
However, after combining three parts together by using Solidworks, i can't extract the volume
is there something wrong?
Old   February 16, 2012, 14:39
Ryne Whitehill
A lot can be wrong hoenstly. Maybe your geometry isnt fully connected?
I would suggest doing an "extract volume" on each of the 3 parts individually, then doing a Unite operation in CCM+ to the 3 volumes.
Old   May 14, 2012, 05:21
karan das
karan75 is on a distinguished road
it can do it in a right way.
karan chananaa.k
karan75 is offline   Reply With Quote
Old   May 14, 2012, 05:28
karan das
we should load geometry or either in CAD modeler.
chananakaran
Old   May 14, 2012, 05:32
karan das
actually I don't have deeply idea about CAD software.
mutthukaran
Old   May 14, 2012, 05:36
karan das
New version supports multithread, a visible assembling tool, a graphic management tool, and can support dynamic deployment.
chris karan
Old   May 14, 2012, 05:38
karan das
StarCCM 1.0 is an OMG's CORBA Component Model(CCM) implementation in c++ language. This software is developed by StarCCM Team.
tomkaranchan
Thread Tools
Trackbacks are On
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
Restart Star CCM server? Apocolapse STAR-CCM+ 1 January 10, 2012 04:56
STAR CCM version 2.08.007 Chris184 STAR-CCM+ 1 February 27, 2010 07:33
StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
star ccm 3.04 jecil CD-adapco 11 July 27, 2008 23:41
