Import CAD into STAR-CD/es-ice
Old   November 28, 2013, 07:06
Default Import CAD into STAR-CD/es-ice
lost.identity is on a distinguished road
I'm trying to simulate an IC engine using STAR-CD/es-ice. I have the CAD .stp file of the engine geometry.
The es-ice tutorial explains how to prepare the surface using STAR-CCM+, I'm wondering if I could import .stp directly into es-ice or another software such as ICEM and do the surface preparation explained in the tutorial. Or do I have to use STAR-CCM+ for this?
Thanks!
lost.identity is offline   Reply With Quote
Old   March 4, 2014, 07:08
Can
cnaksoy is on a distinguished road
You don't have to prepare surfaces by using StarCCM+. For example, I use Hypermesh to prepare surfaces but you have to convert surfaces to .dbs file format from .stp file format and only you can do this in StarCMM+.
cnaksoy is offline   Reply With Quote
Old   March 5, 2014, 01:58
Jing
olhyde is on a distinguished road
i always import .stl surface mesh into CCM+
olhyde is offline   Reply With Quote
Old   March 5, 2014, 02:11
Can
Ok, it is better. But you always have to import .dbs data format in es-ice environment. it means you can prepare surfaces any software you want, but finally you can convert your data file to .dbs data file in CCM+.
es-ice, star ccm+
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
