help to run the engine with user defined fuel
Old   April 2, 2012, 03:24
Default help to run the engine with user defined fuel
raghu
kumar swamy m.c is on a distinguished road
hello
Is there any one run the engine with user defined fuel using es-ice. In case if you had please suggest what are all changes should be make in star controls and pro-star.
kumar swamy m.c is offline   Reply With Quote
Old   April 3, 2012, 11:00
Pauli
Pauli is on a distinguished road
You will need a dropro.f subroutine to provide the liquid fuel properties and you will need to define the gaseous fuel properties in prostar. If you are using liquid films, you'll also need a subroutine to define the liquid film properties.
I'm not sure about the es-ice part or the prostar-es-ice interaction. (I'm not a regular es-ice user.) I've played with it a few times over the years. It seems to be different each time. Maybe someone else can provide additional details.
Pauli is offline   Reply With Quote
[General] Paraview User defined view prapanj ParaView 3 January 3, 2014 20:54
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
user defined sourcen term xck1986 CFX 1 July 8, 2010 08:35
user defined turbulence model manuutin STAR-CD 5 October 14, 2009 05:29
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
