Home > Forums > General Forums > CFD Freelancers
Help with FSI simulation [PL?]
Old   April 8, 2014, 23:52
Default Help with FSI simulation [PL?]
Stanislaw Komorowski
InnovationFinancing is on a distinguished road
We are currently in the initial phase of a project, which can be concisely explained as attempting a controlled descent and ascent of inflated chambers (basis has a shape of a rectangle) under the water to a predetermined depth along with a man sitting on the chamber. The chamber is submerged and surfaced by pumping in and pumping out adequate amounts of water. Unfortunately, the way in which water pours in and is displaced inside the chamber during the immersion leads to a loss of balance by the person on it seated and consequently toppling of the chamber. All geometrical data, material and water flow are known.
We are looking for someone to prepare a FSI analysis leading to a solution of the aforementioned problem, preferably in openfoam or ansys.
Bearing in mind that our engineers are Polish, Polish speakers are preferable, however, the language skills are naturally not indispensable for the task.
contact: skomorowski@innovationfinancingllc.com
Wyjaśnienie PL:
Jesteśmy aktualnie w początkowej fazie projektu polegającego, w uproszczeniu, na kontrolowanym zatopianiu i wynurzaniu komory napełnionej powietrzem o podstawie prostokata pod wode na okreslona glebokosc wraz z siedzacym na niej czlowiekiem. Jest ona zatapiana i wynuarzana przez wpompowanie i wypompowanie odpowiedniej ilosci wody. Niestety, sposob w jaki rozlewa sie woda wewnatrz komory podczas zanurzenia doprowadza do jej przechylenia sie i stracenia rownowagi przez osobe na niej siedzaca. Wszystkie dane geometryczne, materiałowe i wydatek wody są znane.
Wrzucam na wszelki wypadek, jako, że może być dokładniejsze niż wersja ENG.
InnovationFinancing is offline   Reply With Quote
Old   April 9, 2014, 11:24
Hemen Shah
Hemen Shah is on a distinguished road
Hello Stanislaw,
Hi-Tech will be happy to assist you in your project.
We have done projects in the same vertical in Europe, US, and Asia.
Please visit :
Hi-Tech: Engineering Services - CAE, FEA, CFD : http://bit.ly/Hi-Tech-CAE-FEA-CFD-Services
We will be happy to get associated in your projects and provide our services.
For more details you can email me at hemen.shah@hitechos.com.
Looking forward to hear from you.
Regards
Hemen Shah.
Hemen Shah is offline   Reply With Quote
Problem FSI simulation Workbench Huski CFX 0 November 12, 2012 14:14
Ansys FSI and CFX (valve simulation) farianka ANSYS 0 April 17, 2011 16:20
parallel run for fsi simulation??? smn CFX 2 July 19, 2009 04:04
problem in solving fsi simulation siavash CFX 5 July 10, 2009 11:59
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
