Home > Forums > General Forums > CFD Freelancers
Flow past a cylinder
Old   March 1, 2016, 10:47
Default Flow past a cylinder
VISHNU
vishnuambali@gmail.com is on a distinguished road
Following is my UDF for imparting a particular velocity along the cylinder surface.Though the UDF got compiled but the mathematical functions and (execute at end) is not executed...
What might be the reason...Pls help
#include <udf.h>
#include <math.h>
static real k;
DEFINE_EXECUTE_AT_END(execute_at_end)
real time;
time = RP_Get_Real("flow-time");
if(time>190)
k=10;
else
k=0;
DEFINE_PROFILE(cylinder_x_velocity, t, i) /* cylinder x velocity = name of the x velocity */
real y,x; /* variable declarations */
real z[ND_ND];
face_t f;
begin_f_loop(f, t) /* thread = given boundary zone, defined automatically when the UDF is hooked to cylinder boundary, the macro begin_f_loop is applied to all the cell faces*/
F_CENTROID(z,f,t); /* the coordinates of the face centroid accessed by F_CENTROID */
x = z[0];
y = z[1]; /* this will hold the position vector */
if(((x*x)+(y*y)==.25)&&(y>=0))
F_PROFILE(f,t,i)=k*y/sqrt((x*x)+(y*y)); /* return velocity is assigned through F_PROFILE */
if(((x*x)+(y*y)==.25)&&(y<0))
F_PROFILE(f,t,i)=-k*y/sqrt((x*x)+(y*y)); /* return velocity is assigned through F_PROFILE */
end_f_loop(f, t)
DEFINE_PROFILE(cylinder_y_velocity, t, i) /* cylinder y velocity = name of the y velocity */
real z[ND_ND];
face_t f;
x = z[0];
if(((x*x)+(y*y)==.25)&&(x>=0))
F_PROFILE(f,t,i)=k*x/sqrt((x*x)+(y*y)); /* return velocity is assigned through F_PROFILE */
if(((x*x)+(y*y)==.25)&&(x<0))
F_PROFILE(f,t,i)=-k*x/sqrt((x*x)+(y*y)); /* return velocity is assigned through F_PROFILE */
end_f_loop(f, t)
vishnuambali@gmail.com is offline   Reply With Quote
Old   March 20, 2016, 05:40
Kuldeep
ksingh is on a distinguished road
Hi!!
You can write to me on ksingh[at]tserc[dot]in
ksingh is offline   Reply With Quote
2D modelling of flow past a rotating cylinder pds24 Main CFD Forum 1 August 21, 2015 10:50
Flow past an oscillating cylinder (Strouhal number) o_mars_2010 Main CFD Forum 8 May 23, 2014 04:25
Flow past rotating cylinder sam.ho OpenFOAM Running, Solving & CFD 4 October 10, 2013 07:49
CFD help: flow past cylinder harsha00711 Main CFD Forum 1 December 24, 2010 21:19
meshing for flow past a cylinder karthik FLUENT 1 July 15, 2005 06:17
