Home > Forums > CFX
Question about interface
Old   April 19, 2012, 12:37
Default Question about interface
Signo is on a distinguished road
I'm studing a microjet propulsor; the engine is formed by a compressor, a combustor, a turbine and his exhaust nozzle.
I was thinking if it is possible to make a multidomain simulation with a fraction of the combustor (one sixth) and all the turbine. For now I've only done simulation of the compressor and the turbine alone and a simulation of one sixth of the combustor (to reduce the complexity of the simulation.).
I want to compound the one sixth of the combustor with the turbine block; in the attached image I've done it with the stator of the turbine to the one sixth of the combustor, but I don't know which tipe of interface I need to use. I want that the result on the combustor outlet will be duplicated all over the inlet of the turbine like a periodic thing, ie. same temperature pattern, same pressure pattern, same velocity pattern etc.
I hope someone can suggests some solution.
Thanks in advance
Signo is offline   Reply With Quote
Old   April 19, 2012, 12:57
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
This can done with new transient turbomachinery algorithms (time periodic and phase periodic I guess) in ANSYS CFD 14
Far is offline   Reply With Quote
Old   April 20, 2012, 06:59
Thanks for the hint, but if I want to make a steady state simulation (my fault that I don't have specified before) is there some method to have the results obtained from the combustor outlet (one sixth) interfaced with the turbine?
So the sixth of the combustor is the boundary condition placed on the inlet of the turbomachine duplicated six times all over the 360 degree of the turbine mantaining the sixth pattern.
I attached a qualitative image to explain better; the combustor is well simulated with a sixth of his entire volume. The left image is the hypothetical temperature pattern on the combustor outlet, I want to place an interface betweet these two domains where this solution will be the turbine inlet boundary condition of all the turbine, simply by placing 5 more identical outlet combustor results.
I hope this post is not too complex too understand, sorry for my poor english. Thanks in advance
Thread Tools
Trackbacks are On
the macro of c_face_loop and thread_id of interface zhang_pioneer FLUENT 2 December 6, 2010 03:37
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 23, 2010 23:53
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 06:49
Mesh motion applied to an internal interface lr103476 OpenFOAM Running, Solving & CFD 6 March 12, 2008 22:07
Question about interface flow and adaptive mesh Luckyluke (Luckyluke) OpenFOAM Running, Solving & CFD 31 June 13, 2007 04:12
