-   -   solid/air interface heat source problem (http://www.cfd-online.com/Forums/cfx/100114-solid-air-interface-heat-source-problem.html)
nvm2011 April 20, 2012 11:19
2 Attachment(s)
I am doing a simulation with the model exploded below,the whole part is in a natural convection cooling state with the air temperature of 193K,and at the interfaces consists of solid-1 and solid-3(3 interfaces),there is a heat source in every plane with a heat flux of 3000 W/m^2,I don't know how to set the heat flux at the interfaces,do i need set the heat source at the air side or the solid side?and how to set the boundary condition of the interfaces?My previous simulation results gives a rather low temperature compared with my experimental data.
Attachment 12666
Attachment 12667
ghorrocks April 21, 2012 07:40
Either, makes no difference. They are coupled together.
As a source term on the tab in the domain settings of the interface.
nvm2011 April 21, 2012 09:46
@ghorrocks,thank you for your patient explanation.but what term do i need to select in the equation source term?energy or anything else?
ghorrocks April 22, 2012 07:50
Yes, add a heat flux of 3kW/m^2 to the energy equation.
