Problem with a periodic boundary condition
Old   May 7, 2012, 13:26
Default Problem with a periodic boundary condition
martial
chuck209 is on a distinguished road
I have a problem with a periodic boundary condition and i really don't find how to solve it.
In fact I'm trying to make an iteration on my BC at each time step.For instance, my boundary condition could be:
Pstatic(t+1)=Pstatic(t)+DeltaP ,
with deltaP=constant value, and t=time.
To recuperate the Pstatique at the boundary, i use a CEL function:
Pstatique(t)=areaAve(pressure)@outlet.
The problem is that the Pstatic(t+1) isn't equal to Pstatic(t)+DeltaP, and it is always less.
That's why a try to change my CEL fundtion to:
And surprise: the average pressure is decreasing at each time step....(whereas is suppose to be constant)
I think the probleme come from the difference between the Hybrid and conservative value that are always different, but i don't find how to solve it....
is it possible to recuperate the hybrid value in CFX PRE using areaAve(pressure)@outlet?or to directly impose a conservative value?
Does somebody know how to solve this problem?
Thank a lot!!!!!
chuck209 is offline   Reply With Quote
Old   May 7, 2012, 15:18
Ahmet
a_cucen is on a distinguished road
Dear chuck,
Maybe you can use function to do this. You can import a chart that contains pressure changes according to time change. and you can take this function to your boundary condition.
a_cucen is offline   Reply With Quote
Old   May 7, 2012, 16:47
martial
Hi!
Thanks for your answer.
Unfortunately, my CEL is more complicated than the one I give you.I really need to recuperate the previously value (Pressure) to find the next value.
Do you think using a routine function could help me?For this, do I need to use Fortran?
Old   May 7, 2012, 17:00
Edmund Singer P.E.
singer1812 is on a distinguished road
Cant do that within CEL normally but depending on what you want to do, you might be able to delay the update of a variable and get what you want.
Do a search on TRANS_LOOP
singer1812 is offline   Reply With Quote
Old   May 8, 2012, 16:32
martial
thank you. I'm trying to do it with de AV.
But for instance, if I would like to simulate a derivative term like dP/dt, may have other choice than doing:
(P(t+1)-P(t))/deltat
I have to discretize, is'nt it?
Old   May 8, 2012, 22:38
Edmund Singer P.E.
are you trying to do this in POST or while the simulation is running?
Old   May 9, 2012, 15:12
martial
I'm trying to do it when the simulation it's running.
In fact i need to change the BC (static pressure) at the outlet and for that, i have a function:
dP/dt=f(P,axialvelocity)
And i need to use previously value for P because i'm using the following discretisation:
(P(n+1)-P(n))/deltat=f(p(n),axial velocity(n))
Do you know what i mean?
Old   May 9, 2012, 15:21
Edmund Singer P.E.
Yes discretize it. Look up trans_loop for details on how to delay update of additional variable.
Old   May 9, 2012, 16:06
martial
Ok!
I just have a last question: how can i be sure than the delay has been correctly apply?
I mean is it possible to calculate for each step the variable with the delay and the variable once the formula compute?
Old   May 9, 2012, 16:09
Edmund Singer P.E.
You should most certainly do this. Set up a monitor point for the pressure, and another monitor point for the Additional Variable that is delayed.
You should be able to see the lag in the solver manager.
Old   May 9, 2012, 17:15
martial
Thanks a lot!
Periodic boundary condition Arif FLUENT 3 March 9, 2017 02:18
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 05:58
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 29, 2010 00:32
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
Transient outlet boundary condition problem jwillie2000 CFX 1 December 7, 2009 18:07
