Home > Forums > CFX
Assigning pressure to closed fluid domains
Old   August 26, 2012, 16:25
Torque_Converter is on a distinguished road
Send a message via AIM to Torque_Converter
Ahh, makes alot more sense now why that would be of interest. That does have an impact on performance since the centrifugal force means fluid is only going to act on a smaller percentage on the blade (near the hub). Also, it might not be a bad idea to turn on bouyancy in that case as gravity may or may not have a significant impact at certain RPM's.
Generally the inlet/outlet is near the shaft for the turbine, with the inlet being generally on the pump side between stator and pump passage, and outlet being between turbine and stator passage. Periodic, so that helps alot, and you could use a "reasonable" set of boundary conditions to generate something like a matrix of solutions. 70-80 liters/min is a reasonable volume flow thru the TC, outlet pressure, hmmm, not 100% certain of that, but I guess you can take reasonable numbers like 50-90 psi and see what happens when paired with different inlet conditions.
Torque_Converter is offline   Reply With Quote
Old   August 26, 2012, 16:33
Aladdin
Aladdin is on a distinguished road
In your opening, Do I make pump inlet as an Inlet boundary condition with mass flow rate and stator exit as Outlet boundary condition with pressure or what do you think?
Aladdin is offline   Reply With Quote
Old   August 27, 2012, 07:15
The entrance and exit of the TC occurs at the hub (outer portion of the torus), but not towards the core/shell. Placing an inlet domain just on the hub in a small slit between stator/pump and outlet just on the hub between turbine/stator will work. This will be roughly perpendicular to the flow path within the TC.
Old   August 28, 2012, 15:42
Aladdin
Your suggestion is a slit between the pump and stator as an inlet and an outlet on turbine hub. Why on hub? and how this is will be created in mesh?
Old   August 28, 2012, 18:15
This image may help:
http://www.google.com/imgres?hl=en&s...,r:6,s:0,i:160
The fluid enters between transmission case and the pump (near where they meet). Fluid exits down from turbine/stator intersection between the transmission input shaft and transmission case. The basic device is called a ground sleeve. This allows fluid to come in and out at via the same central area, but in different channels. This is important for cooling.
As for meshing. If you are using bladegen/blade editor and turbogrid you can create inlet and outlet blocks by moving the pyramid shaped delimiters.
If you are not using turbogrid with bladegen/blade editor I HIGHLY reccomend using it. But if you aren't, then I assume you have an extracted fluid domain from a cad program. This will work fine, although not as efficiently. You will have to slice off a bit of a chunk at the stator to pump and turbine interfaces, make sure they are periodic and rotating with their respective turbine/stator/pump domain, but make the hub side of these blocks and inlet and then outlet condition as appropriate. How you do this depends on the CAD program, i.e. using perhaps planes or a sketch/extrude like in NX. You will have to play with this. Unfortunatly, getting good at manipulating CAD seems to be an important part of being a CFD analyst.
Old   August 30, 2012, 14:06
Aladdin
I am actually using bladegen and turbogrid. Do blocks can be created in bladegen? I have no experience with doing this. I think I'll go with creating a CAD part and insert it between torque converter parts.
Old   August 30, 2012, 14:36
It's actually fairly easy in turbogrid. I'll do my best to explain how to create these blocks so that you can have faces to apply inlet/outlet without disrupting the flow. If I fail to clarify anything there are a few turbogrid experts at CFX who can help you.
Basically once you export your points to turbogrid and open it up you will see at the inlet/outlet boundaries (really the interfaces between the TC components) that there are white pyramid shaped objects. If you drag these they will follow the hub/shroud lines and make a cut in the domain. These will be your inlet/outlet blocks.
These will need to be meshed, so when you go into your mesh definition control panel (or whatever its called) you will have to click on inlet/outlet domain. The last tab on that menu box will allow you to change the mesh conditions in these domains if you so wish.
Old   August 30, 2012, 16:40
Aladdin
I think I got it. I'll try it and keep you updated. thanks for your comments. They are very helpful.
Old   October 22, 2015, 09:51
jsm
JSM
jsm is on a distinguished road
This might be late reply. Can you please post the image of torque converter modeling with inlet and outlet. I am using bladegen and turbogrid and I cannot make inlet/outlet in turbogrid.
With regards,
JSM
jsm is offline   Reply With Quote
Thread Tools
Trackbacks are On
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 01:11
Calculating the force exerted on an object from fluid pressure amrbekhit CFX 1 January 30, 2011 17:38
vof simulation...magnetic fluid pressure fields. Souviktor FLUENT 0 May 22, 2010 02:19
fluid pressure in cavity Nishan CFX 0 November 2, 2008 19:51
Does star cd takes reference pressure? monica CD-adapco 1 April 19, 2007 11:26
