a hydrocyclone modeling problem
2 Attachment(s)
Hi guys:
I'm recently doing a hydrocyclone simulation with CFX12 and having some problems, I hope I can get some sugguestions or idea here. This is a solid-liquid seperator with tow tangential inlets, I meshed it with structure grids with ICEM, the quality seems to be OK. In the CFX-Pre, two phase massflow rate and volume fraction was assinged dependtenly, 0 static pressure was assigned on the outlets(overlet and underlet) , the fluid turbulence model was selected as SSG RSM, but covengence problems occured. The massage window showed that:A wall has been placed at portions of an outlet..... I did as it recommended to swith the outet as openning, but it didn't work, even to single phase simulation. I also tried with K-E, RNG K-E, and BSL RSM model, all could converge well. So, I want to know, if someone has the similar problems and how can I sovle the problems. By the way, In the simulation, with other converging turbulence models(k-e, RNG K-E and BSL-rsm), I didn't capture the aircore, so how can i get in, is any special setup needed in the CFX-Pre? Any suggestions or idea is appreciated!:) |
ghorrocks:
thank you very much for your idea, I have lenthened the outlet as someone suggested, but it didn't work, even for singlephase flow.After sveral steps of calculation, the residual go down sharply below1e^-6 and the computation stopped "normally". So I don't understand why did this happened. My cyclone has two tangential inlets, so the mesh of the tangential area seems to be OK,but the angle check is poor. So I want to know if this influenced the RSM model calculation. |
I have seen a number of hydrociclones simulated with SST + curvature correction with good results
Ou local Ansys representative once advised to extend not only the outlet but the inlets as well. Hope it helps Best regards |
Good point Luis, the SST model with curvature correction may help here. You may be able to get that to run without all the hassle of RSM.
Yes, any poor quality elements will give RSM a hard time. You need an excellent quality mesh for reliable RSM convergence. Also have a look at the flow with the reverse flow are the outlet in the post processor. You might be able to see where the reverse flow is coming from, and whether it is real. |
Hi,ghorrocks and lffabiani
Thank you for your attention for my problem. Maybe ghorrocks are right. After I do some check and modification in CFX-Pre, some model seems to be OK and could be computed,but some models still couldn't. From OK models, the flow field and preesure is not so good as many orther simulation of cyclone, no air core was obtained. I got the massflow rate of the solid phase from the two outlets, it didn't equal to that from the inlets. For small particles, it seems to be OK, but the outlet massflow rate deviates seriously for largger particles, the result is incredible completely. I am having a headache about it these days. But thank you agian for your ideas and I will have a try! |
