May 11, 2013, 11:36 |
Question about CFX GGI critical situation
Meimei Wang
Rep Power: 15 |
If the fluid domain grids surface A need to have GGI connection to two different grids surfaces B and C (one solid and one fluid). But because of the geometry complexity, the A surface can't be split into two, so the connections with B and C can't be defined separately. But if we define GGI like A with B then A with C, we got the error message 'In Analysis 'Flow Analysis 1' - Domain Interface 'A': The location is already being used for another boundary or interface.' . How to deal with this critical situation?
Best regards, Meimei |
May 12, 2013, 08:16 |
Rep Power: 143 |
You will have to split surface A, even if it is difficult. As you correctly point out, surface A cannot be shared on two GGIs.
May 12, 2013, 10:41 |
Mr CFD
Rep Power: 14 |
Surely it's easy to do this if you're using ICEM and some drawing package for your geometry.
1. In your drawing package make sure surface A is split in two. 2. Import the geometry into ICEM. 3. Create two separate parts in ICEM for the surface A. 4. Export your ICEM mesh to CFX. |
Display Modes | |
Question about CFX pressure averaging in a surface | Anna Tian | CFX | 4 | May 1, 2013 12:04 |
[ICEM] Question about creating porous domain interface for CFX by ICEM | lnk | ANSYS Meshing & Geometry | 0 | July 20, 2012 07:40 |
Question about the shock wave in CFX software | nucharin | Main CFD Forum | 1 | January 25, 2005 09:26 |
simple question about ICEM CFX | sleepinglily | CFX | 0 | October 27, 2004 14:15 |
Question about meshing / solution scheme of CFX | Coriolius | CFX | 8 | August 1, 2004 19:39 |
