April 24, 2012, 08:32 |
Ansys tutorial
slim
Rep Power: 13 |
Hello, I seek a TUTORIAL to simulate a cylindrical flow of a Newtonian fluid by ANSYS and ANSYS CFX FLEUNT. I tried with ANSYS FLUENT but I can not get a flow with constant velocity. I always accelerating throughout the cylinder which have no logic. I tried with ANSYS CFX but I did not understand (there are chemical reactions that I did not need) and I want some help. My account is: http://www.cfd-online.com/Forums/members/slimmsk.html My mail is: slimmsk@yahoo.fr Thank you for all |
April 25, 2012, 08:44 |
Rep Power: 143 |
Your question raises more questions than it explains.
CFX and Fluent are both very capable CFD solvers. If they are doing weird things then you set them up wrong. Do more tutorials and training and things will be clearer. You do not mention chemical reactions, so why are you saying CFX has chemical reactions you do not need. Alternately if you want specific help on your simulation then post more detail and we will try to help. |
April 26, 2012, 17:41 |
slim
Rep Power: 13 |
hello,
I try to simulate flow between two cylinders. Normally I should get a constant velocity profile along the length. But, I found an acceleration along the entire length of the cylinder. Change speed / length axis> 0 normally it must be = 0 thank you merci |
April 26, 2012, 19:37 |
Rep Power: 143 |
This effect is probably real - compressible flows accelerate along a duct due to the fluid density decreasing, all flows (incompressible and incompressible) have the centre line velocity accelerate as the boundary layer develops and the centre velocity accelerates to maintain constant volume flow rate.
April 27, 2012, 07:33 |
Rep Power: 143 |
You have not described what you are doing so I cannot help you. As I already said, this effect can be due to the boundary layer forming cuasing the centre line velocity to accelerate, or it could be the acceleration of the flow due to fricition in compressible flow. As I have no idea what you are modelling I cannot be more specific.
April 28, 2012, 05:48 |
slim
Rep Power: 13 |
hello,
You find this link in a description for what I did. This is another topic that I posted. http://www.cfd-online.com/Forums/ans...ical-flow.html If you have an article, a thesis or a study where I can find an explanation which I can pass it to me based retail? thank you |
April 29, 2012, 08:00 |
Rep Power: 143 |
Your flow is incompressible, so it appears the cause of the effect is development of the boundary layer causing acceleration of the core flow.
So this answers your question, doesn't it? |
April 29, 2012, 16:33 |
#9 |
slim
Rep Power: 13 |
hello,
yes, certainly for me, but I have to find a literature reference indicating the purpose in order to demonstrate the results that I present, and I can not find. Thank you for your appreciable help and motivation for my question. |
April 29, 2012, 20:10 |
#10 |
Rep Power: 143 |
It is simple conservation of volume. No need for a reference, a few lines of maths proves it.
May 1, 2012, 06:47 |
#11 |
slim
Rep Power: 13 |
hello,
if it is not too much, can you help me a little more. thank you |
May 1, 2012, 20:18 |
#12 |
Rep Power: 143 |
Have a look at the flow at the inlet and the flow as it develops. See if you can work out why the centre line accelerates.
May 6, 2012, 21:20 |
#14 |
Rep Power: 143 |
Just let the flow develop over a longer pipe.
May 7, 2012, 13:20 |
#15 |
slim
Rep Power: 13 |
hello
I'm working on a configuration such that the length L = 300mm and diameter D = 25.8 mm. I tried with a length L = 500mm, but I found the same result. even in simulating with a flow of water. I tried with ANSYS CFX and it is similar, and I even found a constant mass flow along the pipe. thank you |
May 7, 2012, 18:14 |
#16 |
Rep Power: 143 |
Have you done a 1D pipe flow analysis to estimate how long the flow development is likely to be?
May 8, 2012, 09:55 |
#17 |
slim
Rep Power: 13 |
No, I work with stationary regime, no time in the calculation.
it is important to wear the transient calculation with a time interval? thank you |
May 8, 2012, 22:23 |
#18 |
Rep Power: 143 |
Flow development occurs both in space and time - the boundary layer needs to grow even for a steady state flow as the flow progresses along the pipe. So work out the pipe lenght required to get developed flow, and I bet you will find your model is a tiny fraction of that.
In other words I think your problem is that your domain needs to be much longer to let the flow develop to fully developed. |
May 10, 2012, 11:29 |
#19 |
slim
Rep Power: 13 |
hello,
I tried a simulation with ANSYS Fluent (I still have some difficulty with CFX): Inlet velocity Outlet pressure with mass flow rate Time step size: 60 seconds Number of time step: 5 Number of iterations / time step: 300 I find the same result I noticed that the solver resolves five blocks of 300 iterations each time, is it recalculates every time? 60 seconds is enough or must I fix a few minutes thank you very much |
May 11, 2012, 00:59 |
#20 |
Rep Power: 143 |
Use the Fluent forum for questions on Fluent.
These are pretty basic questions you are asking - surely you know how to determine if the flow is developing in time or not. |
ansys, cfx, flow, fluent |
Display Modes | |
Ansys tutorial | slimmsk | ANSYS | 0 | April 24, 2012 08:31 |
Tutorial ansys | slimmsk | FLOW-3D | 0 | April 24, 2012 08:30 |
Ansys Dynamics tutorial | kajal | ANSYS | 0 | May 21, 2011 02:14 |
Ansys 13.0 Explicit Dynamics Tutorial | WenZyn Lim | ANSYS | 0 | April 15, 2011 10:57 |
Questions about ANSYS ICEM CFD tutorial | pquispea_m5 | ANSYS Meshing & Geometry | 3 | December 5, 2010 16:58 |
