Reverse Particle Tracking
Old   May 14, 2012, 13:07
Default Reverse Particle Tracking
Shawn
Shawn_A is on a distinguished road
Is there a way to do reverse particle tracking? I have a situation where I would like to see where the fluid came from that is interacting with my blades. Ideally I would be able to specify a number of points from which I could drop particles into my fluid and then track them backwards in time to determine how much the flow is diverging around my rotor.
Regards,
Shawn
Shawn_A is offline   Reply With Quote
Old   May 14, 2012, 18:44
You might be able to do this with some advanced post processors such as ensight or Fieldview. Without them I suspect your only choice is to release massless particles as the simulation runs, and in post processing find a particle in the region you want and track it back.
Alternately if the flow is steady state, or the velocity of the flow is high compared to the change in the flow, then you can use normal streamlines and they have an option to integrate backwards.
ghorrocks is online now   Reply With Quote
Old   May 16, 2012, 04:37
Timon is on a distinguished road
In post you can also filter you're particle tracks based on the location where they end up.
Timon is offline   Reply With Quote
dispersion model with lagragian particle tracking model for incompressible flows eelcovv OpenFOAM Running, Solving & CFD 54 April 10, 2018 09:36
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 00:59
massless particle tracking problem Renold FLUENT 0 January 26, 2011 14:23
Particle Tracking for ion Jun CFX 2 August 31, 2010 08:19
Number density tracking rather than particle tracking Rebecca Main CFD Forum 2 April 23, 2009 12:52
