-   -   Flow through pipe bend tutorial - Solver Error (http://www.cfd-online.com/Forums/cfx/101850-flow-through-pipe-bend-tutorial-solver-error.html)
sledfreak17 May 15, 2012 13:14
Anyone have any ideas of what the issue could be?
http://i644.photobucket.com/albums/u...AnsysError.jpg
ghorrocks May 15, 2012 19:35
Sounds pretty obvious. You do not have a valid definition file. This is probably because of a problem in CFX-Pre so it did not generate a def file and the rest of the workbench system failed to execute because of it.
sledfreak17 May 16, 2012 09:44
Thanks,
To be more specific, this is the problem in CFX-pre:
http://i644.photobucket.com/albums/u...-PRE_error.jpg
Lance May 16, 2012 10:04
The error says that you have specified two boundary conditions at the same location (inlet). Why not change it?
sledfreak17 May 16, 2012 10:29
The intention was obviously not to specify two boundary conditions at the inlet,
there is no-slip at the walls, symmetry of the side faces and inflow and outflow boundary conditions specified.
