Flow through pipe bend tutorial - Solver Error |
May 15, 2012, 13:14 |
Andrew Smith
Rep Power: 13 |
Anyone have any ideas of what the issue could be?
May 15, 2012, 19:35 |
Rep Power: 143 |
Sounds pretty obvious. You do not have a valid definition file. This is probably because of a problem in CFX-Pre so it did not generate a def file and the rest of the workbench system failed to execute because of it.
May 16, 2012, 09:44 |
Andrew Smith
Rep Power: 13 |
Thanks,
To be more specific, this is the problem in CFX-pre: |
May 16, 2012, 10:04 |
Lance
Rep Power: 22 |
The error says that you have specified two boundary conditions at the same location (inlet). Why not change it?
May 16, 2012, 10:29 |
Andrew Smith
Rep Power: 13 |
The intention was obviously not to specify two boundary conditions at the inlet,
there is no-slip at the walls, symmetry of the side faces and inflow and outflow boundary conditions specified. |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 07:11 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 06:12 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
