-   CFX (
-   -   Moving Turbogrid mesh (
olegmang May 16, 2012 11:40
Hi guys. Does anyone know how to move turbogrid mesh?
The problem is next: I have blade geometry in turbogrid (hub, shroud, blade) and create a mesh. What i want is to parametrize the movement of whole mesh domain (translate it) along one of the axis in Workbench. I need this to simulate gradual axial clearance change between rotor/stator.
Is there any possibility to do this in Workbench?
TIA, Oleg.
ghorrocks May 16, 2012 18:52
In CFX-Pre you can do simple mesh operations - move mesh about (translate, scale, rotate), copy and delete mesh regions. This should cover what you need.
olegmang May 17, 2012 05:37
Thanks for the reply, but i've already known it. The question was: Is there any way to parametrize this translation and then use it as Workbench input parameter?
ghorrocks May 17, 2012 06:03
I don't think you can parameterise CFX-Pre. You can script it, that could generate the meshes for you.
olegmang May 17, 2012 07:04
I thought so :(.
But any way, thanks for your time.
