Home > Forums > CFX
[CFX 12.0]Windows XP 32bit // ERROR #001100279 Not enough free memory
Old   May 17, 2012, 22:15
Default [CFX 12.0]Windows XP 32bit // ERROR #001100279 Not enough free memory
June
msormania is on a distinguished road
Specifications
Dell Precision Workstation T3400
Windows 32bit XP Professional
3.25GB DRAM (4GB: 2*2GB PC6400 667Hz Samsung)
Intel Core 2 Duo E8400 3.00Ghz/2.99Ghz
Nodes
2 millions
Multiphase (Water-Air) incompressible transient NS homogeneous equations with two immersed solids rotating in the multiphase domain
ERROR #001100279 has occurred in subroutine ErrAction.
*** Run-time memory allocation error ***
Not enough free memory is currently available on the system.
Could not allocate requested memory - exiting!
The CFX Solver for system Fluid Flow did not produce a results file. Detailed information can be found in the output file for the run, which can be viewed by selecting Display Monitors from the Solution cell. Cell A4
Ans.Core.Commands.UserReadableFailure: The CFX Solver for system Fluid Flow did not produce a results file. Detailed information can be found in the output file for the run, which can be viewed by selecting Display Monitors from the Solution cell.
at Ans.CFX.CFXCore.Data.CFXSolutionSource.HandleRunFa ilure(CommandContext context, String outFileName, String rawSolverOutput)
at Ans.CFX.CFXCore.Data.CFXSolutionSource.ReconnectRu n(CommandContext context, SolverBackgroundTask task)
at Ans.CFX.CFXCore.Data.CFXSolutionSource.RunSolver(C ommandContext context, Boolean forceResume)
at Ans.CFX.CFXCore.Data.CFXSolutionSource.Update(Comm andContext context)
at Ans.CFX.CFXCore.Commands.UpdateSolutionCommand.Exe cute(CommandContext context)
at Ans.Core.Commands.Concurrency.CommandWorkUnit.exec uteInContext(CommandContext subContext, IExecutionEngineCallback tracer)
at Ans.Core.Commands.Concurrency.BaseWorkUnit.doExecu te(IExecutionEngineCallback executionEngine, CommandContext subContext)
at Ans.Core.Commands.Concurrency.BaseWorkUnit.Execute (IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ans.Core.Commands.CommandFailedException: The CFX Solver for system Fluid Flow did not produce a results file. Detailed information can be found in the output file for the run, which can be viewed by selecting Display Monitors from the Solution cell.
Command: CFX.UpdateSolution(Container="Solution")
at Ans.Core.Commands.CommandAsyncResult.RethrowFailur eException()
at Ans.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
at Ans.Core.Commands.CommandAsyncResult.Wait()
at Ans.ProjectSchematic.Data.CellTemplateEntity.Updat e(CommandContext context, IProgressMonitor progressMonitor, DataContainerReference container, List`1 downstream)
at Ans.ProjectSchematic.Update.UpdateImpl.updateCell( CommandContext context, UpdateTask task)
at Ans.ProjectSchematic.Update.UpdateImpl.<>c__Displa yClass25.<updateCellAndDependencies>b__24()
at Ans.ProjectSchematic.Update.UpdateImpl.executeWith SelectedErrorBehaviour(Op op, UpdateTask associatedTask)
I changed the advanced solver option "Maximum allocation factor" 1 to 1.4 but, it does not work.
How can I resolve this problem?
msormania is offline   Reply With Quote
Thread Tools
Trackbacks are On
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 17:50
maximum memory 32bit fluent version korni FLUENT 6 May 19, 2005 20:21
ERROR-- PDA free: Attempt to free memory...... tuks CFX 0 May 5, 2005 08:34
Not enough free memory is currently available Kang CFX 6 September 17, 2004 05:33
How to free memory after running Fluent ? David FLUENT 1 February 27, 2004 03:59
