Home > Forums > CFX
Fully Developed Conditions for Microchannel Heat-Sink (MCHS))
Old   June 2, 2012, 19:40
Question Fully Developed Conditions for Microchannel Heat-Sink (MCHS))
Behzad
mech-engineer is on a distinguished road
Hi daer friends
I want apply fully developed conditions (hydrodynamics and temperature conditions) at the end of a micro-channel heat sink (MCHS) that nanofluid flowing it.These conditions at outlet include in: 1)pressure equal to ambient pressure. , 2)Velocity gradient across the length of MCHS equal to zero. , 3)Temperature gradient across the length of MCHS equal to zero.
Please tell me how check these conditions for simulation and apply them via CFX?
mech-engineer is offline   Reply With Quote
Old   June 3, 2012, 07:02
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Don't you mean velocity and temperature gradient is zero in the flow direction?
The simplest way to do these sort of flows is by using a periodic boundary with your defined flow rate and heat addition. Then it will converge on the full developed solution.
Old   June 3, 2012, 09:48
Behzad
no,zero gradient only apply on outlet conditions.Can I give these conditions without apply of periodic conditions?
Old   June 3, 2012, 19:34
I see, you want to apply a zero gradient BC, you are not interested in fully developed flow. A zero gradient BC does not mean the flow in front of it is fully developed by the way. To get fully developed flow you need a duct long enough for it to develop. It has nothing to do with the BC - and this is the same for a physical experiment as well.
CFX does not have zero gradient BCs, it has flow variables convected from the domain (with a few exceptions, see the documentation for those).
Old   June 3, 2012, 20:07
Question
Behzad
How I can get enough length for simulation to ensure that flow is fully-developed at outlet.The geometry of my problem is a trapezoidal microchannel haet sink that dimensions of front area include in:400 micron (large base),300 micron (small base),350 micron (height),base angle=54 degree and length of microchannel is 10 millimeter normal to front area.Does these dimensions enough for you to answer me about fully developed conditions?
Old   June 3, 2012, 21:22
No, you cannot work out fully developed flow from those details as the fluid properties also contribute. And I do not have time to work it out for you anyway.
Read some basic fluid mechanics textbooks on flow development length. Alternately you can do a sensitivity study by testing various lengths and seeing if you can see it converging with increasing length.
Old   June 4, 2012, 05:16
Question
Behzad
With use of double precision at CFX-Solver Manager all of the equations (mass and momentum,energy,volume fraction) converge but when I use serial option at CFX-Solver Manager, energy equation can't converge.According to this comment, do you think my length is enough for obtaining a fully developed solution?
Old   June 4, 2012, 07:06
Whether your simulation achieves your specified residual convergance tolerance or you use double precision numerics has nothing to do with whether fully developed flow has formed.
Thread Tools
Trackbacks are On
Fully developed temperature profile for laminar/turbulent flow in FLUENT raghu.tejaswi FLUENT 10 November 7, 2012 10:57
there is a problem with fully developed Nusselt number eeman Fluent UDF and Scheme Programming 4 September 24, 2012 01:36
Fully Developed Flow in Star-cd SMM STAR-CD 0 September 5, 2011 22:08
udf for 3D laminar fully developed flow salman FLUENT 0 November 9, 2006 22:45
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
