remeshing using icem and cfx error
Hi
i am trying to move an object inside water in a closed channel and making use of remeshing using icem and cfx combination, but am getting the following errors (well i am able to do remeshing using icem and cfx for one time only but when remeshing is required in simulation for next time it fails and gives the following errors) : An error has occurred in cfx5solve: | | | | Error reported by IO module: iif_open: the file is not in CFX-5.x | | format | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Error reported by IO module: iocnt: open the primary file failed | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Error from IO module while opening E:\moving plate\moving | | plate_001.dir\moving plate.uns.bak: | | | | "iocnt: open the primary file failed" | | | | IO_BAD_FILE(20): Invalid def/res file. File could be corrupted. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | WriteToFile failed - dataset write filed Thanks in advance... |
did you solve it?
