Home > Forums > CFX
FSI: ANSYS-Multifield coupling + mesh displacement
Old   June 12, 2012, 15:58
Default FSI: ANSYS-Multifield coupling + mesh displacement
Geraud is on a distinguished road
I am currently working on a FSI case with ANSYS Workbench/CFX.
I have a pretty simple cylinder representing a tank full with water and a vibrating membrane at the bottom.
I set this membrane as an interface for the ANSYS Multifield coupling. Then when I create the boundary conditions I define it as a wall with the following options:
Now I need to make the all device oscillating horizontally. So I put, for each boundary, the mesh motion option at "Specified Displacement" like this:
But for the membrane, I already have set the mesh motion option as ANSYS Mutlifield so I can't input the displacement.
> Have you any idea on how should I proceed to set both displacements in the same time (the vertical one from the membrane and the horizontal one from the all device)?
Thanks.
Geraud is offline   Reply With Quote
Old   June 25, 2012, 19:30
Default mesh motion
blackehsan
ehsanblack is on a distinguished road
I can see that u managed to have "mesh motion" option. my problem is kinda like urs but the thing is for my plate when I create a new boundry and then in basic setting i put "wall" and then define "location: interface", then ib "boundry details" I have no "Mesh motion" option. would you plkease tell me how it works?
Tnx
ehsanblack is offline   Reply With Quote
Old   June 27, 2012, 12:07
Peter Galimutti
p.galimutti is on a distinguished road
Your problem, initially is a vibration/harmonic one.
You look like you have a solid container but you are trying to do a semi-FSI (between one-way and two-way fsi) and two-way fsi
Give a force to the solid container, so that they displace vertical and horizontal oscillatory motion desired.
Then give all FSI interfaces Ansys Multified.
From my imagination once you've done this you might have to remesh your fluid and or solid domains, because mesh distortion is too high (assuming you have enough oscillatory forces or the fluid is less denser). But this is a second part.
Check the thread below for more info on Re-meshing or CFX manual
"ANSYS CFX with Remeshing in ICEM CFD"
p.galimutti is offline   Reply With Quote
Thread Tools
Trackbacks are On
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
FSI - Specified Mesh Displacement Vinzent CFX 2 September 17, 2010 07:09
FSI error requesting Total Mesh Displacement niraj12321 ANSYS 0 July 23, 2010 23:49
FSI mesh stiffness help realanony87 Main CFD Forum 2 June 21, 2009 15:29
